Question about Remington R9370 Electric Shaver
R9370 battery replacment
Is the Remington R9370 one of thosse razors that will not allow user replacement?
SOURCE: Battery Replacement for Remington PG-300 Beard Trimmer
Hi
The manual will give you info on the battery that is inside the trimmer.If you can get to the battery then buy same TYPE or similar to the original---VOLTAGE/CURRENT RATING/CHARGING etc and size, connection
Hope this helps
Jay
Posted on Nov 17, 2007
SOURCE: Remington R 9500 razor needs a battery
well this is what the problem is i need to know how my wiring goes at the top of the 76's
Posted on Jan 28, 2009
SOURCE: I need to replace the battery for a Remington
Surfing the internet is the best way to find the battery. Here's a link which might be a place you could start your search:
http://spendoo.com/1496-buy-shaving-appliances.htm
You may have to remove the battery and use the part number in your search.
It's not extremely difficult to replace the battery. There may be solder connections to deal with.
Posted on May 13, 2009
VtToolMan
  • 704 Answers
SOURCE: batteries for ms5500
Give the folks at electricshaver.com a try. I tried to look up the replacement batteries for your shaver, but didn't find your model number listed on their site.
However, you can give them a call and see if they have them available, as many shavers use similar batteries, you just have to know the cross-reference list to figure it out. There phone number is 1-888-476-1785.
Normally I can provide the replacement part numbers for electric shavers and provide a link to the parts list for them/
Hope you find this Very Helpful and best regards!
Posted on Sep 24, 2009
woodchuck789
  • 4070 Answers
SOURCE: The rechargeable battery on my
E Bay is a good place to find razor parts. They have new parts and you don't have to bid on them since they have a Buy It Now price.
Posted on Dec 09, 2010
HOW TO REPLACE BATTERY REMINGTON RAZOR R-4100
Hi Docle60,
You'll only need a couple of tools and a little time. The steps are pretty easy.
  • Take your electric razor apart to find out what type of replacement battery you need.
  • Buy your replacement batteries.
  • Remove your old batteries
  • Solder the new batteries and place.
  • Reassemble your razor and test it.
There are a couple of ways to buy your replacement batteries.
  • Do a google search using the model number of your razor.
  • Find the original battery model number and search using that
  • Find the original battery voltage and milliamps and search using that information.
Using the model of your razor, you might want to try shavers.com or, If your not good at soldering, purchase pre-tabbed batteries already soldered on them. If your batteries are a standard size, you can purchase them from Amazon at a reasonable price.
Hop this helps
David
Dec 01, 2017 | Remington Health & Beauty
I need to replace the battery in a Remington women's razor model wdf 1600
  • Open battery compartment
  • Note correct polarity and remove
  • Install new battery
  • Close battery compartment
  • Test operation
If the razor does not work, the replacement battery may be defective
Jul 12, 2016 | Remington Health & Beauty
Remington Electric Shaver..How do I disassemble a Model XLR 900. 8BF2-1C. I want to replace the battery.
Unfortunately these rechargeable razors are not designed to be easily serviced by the home user.
Changing the battery will definitely involve a bit of searching for the multiple screws which hold the case together and then disassembling the case to access the battery compartment. Just watch out for any screws which may be hiding under the rubber padding pieces. You will then likely be required to desolder the old battery out and then resolder your new battery back into place.
Here is a link to a site which describes the various methods for disassembling battery powered shavers:
http://k0lee.com/2008/04/replacing-remington-and-norelco-shaver-batteries/
Here is a link to a replacement battery available for your model:
http://www.batteryweb.com/cordlessrazordetail.cfm?ID=238
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
Thank you very much and good luck.
May 14, 2011 | Health & Beauty
I haven't used my shaver for more than a year and now it refuses to charge. Nothing happens when I plug it in.
Batteries are probably dead and need replaced. You will find the correct battery type at shaveroutlet.com. See link below. You will need to order two batteries
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
To replace, you will need to remove the back cover. To do so, remove the three screws on the back. One is easily visable. Slide trimmer up to see second screw. The third screw is tougher...you need to pry out the trimmer at the top where it flips out from the shaver body to get to it.
Once removed, you will be able to access the batteries. They are soldered to wirdes. Unsolder the old ones and solder in the new ones
If you are unable to do this yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Aug 22, 2010 | Remington R9370 Electric Shaver
Dead batteries
Hello. Since you did not specify which razor you have I am enclosing a blog which describes the process for most all norelco razors. Regards, Joe
Dec 26, 2009 | Health & Beauty
What batteries are in the reminton ms2 390?
They have Ni Cad Batteries.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 07, 2009 | Remington MS2-390 Electric Shaver
Remington R9370 Electric Shaver Logo
157 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
