Question about Sony KP-46WT510 46" Rear Projection HDTV
Double images When the tv is turned on, there is a double image and I've already tried the flash button but to no avail.
  • 1,694 Answers
Re: Double images
Needs convergence circuit repair----Replace STK IC's and
check for burnt resistors or open fuses.Then touch flash focus..
Let me know............T.
Posted on Nov 01, 2007
0 characters
3 Points
My sony KP-46WT510 has double images and the edges are red and green
Try pressing the Flash Focus button on the TV to adjust the convergence of the TV.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 22, 2010 | Sony KP-51HW40 51" Rear Projection...
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Double screen image
Double image shows that TV got problem of Convergence Out ICs failure and will be replaced two ICs mounted at D Board of TV.
ICs, STK392-360 are available in Part Store, click to see an image and price info.
Apr 27, 2009 | Sony KP-65WS500 65" Rear Projection...
Double image
Problem seems in convergence out section.
TV needs Convergence Out ICs replacement.
If you have TV repair experience and know good soldering work then you can give it try OR get help of qualified TV tech to fix it.
If you need further help, let me know.
Dec 30, 2008 | Hitachi 51GWX20B 51" Rear Projection...
there is a problem with tthe convergence section this is something a tech can do
Sep 23, 2008 | Toshiba TZ50V51 50" Rear Projection...
Double image
yes you just need two ICs
Jul 12, 2008 | Akai PTH5498 54" Rear Projection...
60" Phillips HDTV Rear Projection
You need new convergence ICs two of them numbers STK392-110 they are available at the following link and they provide free installation instructions with pictures as well as free online tech support while you do the repair which takes about an hour. Heres the link.
Apr 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Double image.
First when replacing the small sig. board a full convergence must be done,the other trouble is most likely the front panel buttons,this is a repair a service center must do,sorry best i can do from here
Mar 10, 2008 | RCA Scenium HD65W20 65" Rear Projection...
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
53fdx20b double vision?
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
Oct 18, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
82 people viewed this question
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
