Question about Sub-Zero 690 Side by Side Refrigerator
Sudden loss of refrigeration
Technician came and said that the evaporator coil in my sub zero fridge has to be replaced and that it is under warranty but not the labor??? He said it will be $550 estimate to fix. Is that possible???
I paid $900 to replace the compressor and evaporator. The evaporator went back out again within a year and labor was $300+, but part covered by parts warranty. Compressor lasted maybe another year (2-1/2 years from installation) and I didn't even bother to call repair service. Instead bought a 31.5 Kenmore made by LG for $1,399 with a small dent in the door. DON'T BUY SUBZERO.
Posted on Jul 28, 2012
    Problem Solver:
Evaporator coil cleaned fan replaceds and now refrigerator runs non stop.
THANK YOU
Posted on Sep 01, 2009
  • 159 Answers
Why does it need to be replaced but in south afrika it costs r400.00 and labour r400.00 total cost r 800.00 but what is the problem maybe i can assist
Posted on Jun 17, 2009
Sub zero evapolator replacement cost
900 to 1200 dollars depending on the model and depending on the freon they use,it takes around 11/2 to 2 hours to do the job but special equipment is needed and this is also what you're paying for.
Jun 05, 2012 | Sub-Zero 642
Refridge temp
Lets go over the way a sealed system works. There is a highj side and a low side. The low side is the side that passes through the evaporator coils inside the machine. Most times on the freezer side only, but sub zero has independent sealed systems for each side. Once it goes throug the evaporator its then condensed into a liquid state, the high side. This is also the hot side. Well, lower pressures in the low side would logically mean lower temperatures. So for the refridgerator not to freeze more freon is used on it to keep the low side pressure higher than normal, giving the cooling effect verses freezing. So, and here is the bad part, if you are seeing ice build up in the refridgerator side you have a freon leak some where allowing the pressure to be less than required to keep it above freezing. Call a service technician and depending on how the model, sub zero warranty is parts and labor covered for the first 6, and only parts from the 6-12 year.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 27, 2012 | Sub-Zero 642
Why is vacuum condenser light blinking
this is usually a leak in the evap coil,if it's under 12 years old the coil is still under warranty.sub zero is a great machine,the only problem is that the evap coil behind the back wall in the fridge section leaks or a hole develops.the freon leaks out and the fridge section will continue to get warmer,the vacumm coil lite will come on.i've seen this happen to some machines that are 3 years old it happens.you need to get a tech in,he'll recover the gas,evacuate it,replace the coil and add new freon in,if it's under warranty it will be 650 to 750,or if not under warranty 11 to 12 hundred dollars to repair.
Dec 29, 2011 | Sub-Zero 650 / O Bottom Freezer...
Refridgerator does not get cool enough
Buttom freezer Sub Zero. Replacing evaporator for fresh food section.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
Although my sub zero 642 is holding the temperature, there is water leaking from underneath the refrigerator every day onto the floor. Sometimes it is heavier than others.
it's condensate from the evaporator coils. when the humidity collects on the coils, it should drain into a pan under the fridge that gets evaporated from the hot-side line. check to see if the condensate tube from the coils is still in the pan.
Jul 29, 2009 | Sub-Zero 642
My side by side sub zero fridge has frost building up on the back wall of the refridger ator side it is about 1/2 inch thick
I had the exact same problem. It was the evaporator coil had a leak. The coil is covered under waranty the labor is not! It was $295.00 labor and $48.00 for the gas recharge.total $343.00. Hope this helps! Yes, the price was high but it fixed the problem.
Part # was 4204420
Ed
May 27, 2009 | Sub-Zero 690 Side by Side Refrigerator
Refrige is 48 and freezer is 0 model 532
Fixing Freon Leak by replacing evaporator coil on Sub Zero refrigerator
May 19, 2009 | Sub-Zero 642
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
My Sub-Zero 611/O is not cooling enough. The temp is 0 in the freezer and 46 in the fridge. I vacuumed very well the condenser. I can't tell which compressor is running. There are two, one larger than the...
More than likely the fan inside the back of the unit freezer compartment is not working and causing the freezer to freeze up.need to pull pannel off inside back of freezer and replace fan
Jan 14, 2009 | Sub-Zero 611 / O Bottom Freezer...
Sub zero side by side
evaporator leaks freon, made a video on how to replace it
Oct 09, 2007 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Sub-Zero 690 Side by Side Refrigerator Logo
378 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
