Question about Maxtor OneTouch A01B080 80 GB Hard Drive
My Maxtor Hd Wont show up anywhere in my laptop when i plug it in
I just bought this Maxtor 80gb HD and plugged it in to both the power and my laptop which has Vista basic. It doesn't show up at all in my computer or disc manager. My computer doesnt even acknowledge that a drive is there. The light on the drive is on solid blue, and it sounds like it is working. I plugged it into my desktop which is XP and it shows up in disc manager. Why isnt it doing this in my laptop? Is it not Vista compatable? Help me please. If i cant get a solution Ill return it.
  • d_razr17 Jun 18, 2009
    Yea it has 3 usb ports and i tired each of them. It still wouldnt detect...
  • 46 Answers
It should still detect even though your using vista does your bios setting have usb2 enabled?? otherwise try a different usb port
Posted on Jun 17, 2009
  • Scott Rawlings Jun 18, 2009
    right. try plugging it in and going to device manager and see if there is any devices with a ? next to it.
Maxtor DiamondMax Plus 9 80GB 6Y080L YAR41BW0 Hard Drive ATA/133 HDD Internal HD not reconizing in any computer .think it is not getting any power to HD so the PCB Board i think might be gone.any help be...
Power comes from the power supply. Check yellow and black and red and black. You need both 5v and 12v. Are you sure you have the jumper set correctly for the application? Master or single - master with slave present or some computers require CS (cable select)
Dec 05, 2009 | Maxtor Hard Drive
PC will not see Maxtor 80GB DiamondMax Plus 9 as seconary slave.
Two thing,
First, never use a Maxtor HDD as a slave to a CDROM/DVD, doesn't work and tends to cause stability issues. So try swapping the jumper on the CD/DVD to slave and setting the Maxtor to Master, this should get it working.
Second, if it is showing up as 33GB, you have the Jumpers set to limit capacity(designed to avoid troubles on older systems. If this is the case, you likely have a single jumper in the center row of pins between the power and data cables. If it only works as master at the moment, then you likely have the neter row(limit size pins) and the one closest to the data cable(Master Pin) both plugged in.
Change your DVD/CD to slave, remove the limiting jumper and ensure the Master jumper is installed on the Maxtor, then be sure the end connector on the ATA(likely marked master) is plugged into the Maxtor and the middle connector(Slave) is plugged into the DVD/CD, this should have you all fixed up.
Hope this helps FixYa,
Chris
May 19, 2009 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Need drivers for a Maxtor 80GB Onetouch III Mini edition
I have a Maxtor Ext HD myself. Maxtor has a website. Try www.maxtor.com or Google it and you will find their web site. Then search for your HD and do a search for the download of the drivers needed for your HD
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
Mar 13, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Light turns on but My Computer does not recognize the drive
Sounds like you lost the drivers for your external. W/ out an online PC you cannot download them either. Do you have a friend that could do this on their PC? That is the only way.
Feb 16, 2009 | Maxtor OneTouch III Mini Edition 120GB...
I cant detect my USB external HD for more than a minute.
There is probably a fault within the hard drive, the circuitry of the housing or perhaps the usb lead.
It would be as well to check the power supply first as some of them are less than reliable and are apt to provide too much voltage.
Jun 01, 2017 | Seagate 80GB USB 2.0 External Hard Drive...
Maxtor 3200 backup drive not recognized in my computer to access
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&message.id=510
Re: whishels
Options Options
eltigre
New Visitor
eltigre
Message 23 of 61
Viewed 3,676 times
My Maxtor 3200 died also. I took the following steps to get it running again.
(1) Remove plastic box from around unit. Carefully stick a screwdrive in the case division and pry it apart. It is not easy, but do will finally come apart.
(2) inside you will find a perforated metal box. There are two screw on each side of the box. Remove and separate the two halves.
(3) there you will discover that inside is just an ordinary Maxtor hard drive like you would buy in the electronics store. Attached to the HD is a PC board. There are 3 screws holding the PC board down. Remove the screws and carefully remove the HD and PC board.
(4) unplug the powere plug and the IDE interface from the HD. Now you have a HD that you can install in your own case (as long as you have a desktop unit and not a laptop).
(5) I installed the HD in an empty slot, connected the IDE cable that was already there (between the CD and IDE interface), plugged in the power plug, fired 'er up, and voila, works like a champ.
I suspect that the problem is in the interface (PC board), since the only thing I did was remove that from the equation. Hope this helps
Kudos! Thanks!
09-09-2008 09:36 AM
Dec 31, 2008 | Maxtor BASICS Personal Storage 3200...
Maxtor Onetouch 500GB went dead
if there is warranty take it back to the shop you bought it from.
Dec 31, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Connecting Hard drive to laptop
I assume that the "2 cables" are actually joined to gether...
Yes just plug the 2 USB connectors in as dirceted.
The USB drive must require more than the 500mA that the USB spec allows for each port. This is a reasonably common solution
Jul 16, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor OneTouch A01B080 80 GB Hard Drive Logo
351 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
