Question about Kenwood DNX7100 Car Video Player
Kedwood DNX7100 unresponsive touchscreen and buttons
I'm having some problems with my Kenwood DNX7100. It turns on fine, but the touchscreen is unresponsive and so are the front buttons. The only exception is the Eject button: nothing happens if I do a short press, but if I hold it a little longer, the screen goes all the way down to the SD slot.
I'm electrically inclined so you can be as technical as you need to, I just don't know where to start on this problem. Can Anyone help? Thanks!
  • 5 Answers
SOURCE: DNX7100 Ublock
You need to have the 4 number password to unlock it
Posted on Aug 08, 2008
SOURCE: Kenwood DDX7017 Screen has no color and it won't eject
Had the same thing happen to me. All you have to do is use a pen or a paper clip and push the reset button located on the front of the unit. It cleared right up.
Posted on Dec 14, 2008
SOURCE: Bypass emergency brake switch on 92 Legend w/Kenwood DNX7100
ground the green emergency brake wire just hook it into the radio ground and that will fix it
Posted on Dec 26, 2008
  • 4 Answers
SOURCE: Won't read an SD card
It sounds like either your GPS plug came out of the back of the unit, or your gps does not have a clear view of the sky, or if the gps is mounted on a trunk that opens and closes a lot the wire can break inside. I dont think the software is your issue, just to make sure if you update make sure the update file is the only file on the card, if there are other files (left over pictures, etc) they can cause the unit to disreguard the whole card.
Posted on Jul 11, 2009
Shuttle83
  • 1139 Answers
SOURCE: Kenwood KVT-817DVD screen goes black, have to reset constantly
Hello johnnychi925,
The unit appears to have been installed on the 12vdc connection that is on the same circuit as the the vehicle's ignition switch. This means that when the ignition is turned there is a rapid drop in voltage which cause the problem with your device. You need to connect the device to a 12vdc circuit that comes straight from the battery and does not connect to the ignition circuit. Now for another possible cause if the 12vdc you are connected to is from the battery and not the ignition connection. The battery could be dropping below 12vdc during the starting of your vehicle. This could be the sign of a malfunctioning battery, or a problem with the car's electrical system.
To test out if the battery ids dropping below 12vdc I would suggest connecting a voltmeter to the - and + of the battery and starting the car. The voltage should drop but not below 12vdc.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jul 12, 2009
Kenwoods DNX7100 to turn out black screen and buttons only light up without no thing more, some solution
Check your power wires and fuses also u should have a master reset that u could push in its really small so you'll need the tip of an ink pen
Nov 04, 2013 | Kenwood DNX7100 Car Video Player
How to load iphone phone book to kenwood dnx7100
This unit does not support iPhone's address book.
Apr 07, 2009 | Kenwood DNX7100 Car Video Player
Nov 29, 2008 | Kenwood DNX7100 Car Video Player
The blue lights connected to the volume bottoms don't come on any
It may be a fault wire connection inside the device. If you still have the warrant info either from Kenwood or the place you bought it, I would see if they can get it repaired.
Nov 12, 2008 | Kenwood DNX7100 Car Video Player
DNX7100
look on pg 81 of the manual. follow the procedure to deactivate the security code.
Sep 11, 2008 | Kenwood DNX7100 Car Video Player
DNX7100 Ublock
Jun 30, 2008 | Kenwood DNX7100 Car Video Player
Kenwood DNX7100
or the parking prake wire is not grounded... that's what happened to me. Just find a spot to ground the parking brake wire and video should appear.
Feb 15, 2008 | Kenwood DNX7100 Car Video Player
DNX7100 Remote inop
The problem I had was with the remote control unit for the steering wheel controls. It shorted out. The head unit was fine. But, when the sterring control unit is shorted it also prevents the hand held remote from working.
Jan 01, 2008 | Kenwood DNX7100 Car Video Player
Kenwood DNX7100 screen won't tilt back up after putting in CD
Yes opening the unit with the eject button then manually closing the unit halfwaly, and disconecting the battery for like 30 secs.... Here
Dec 04, 2007 | Kenwood DNX7100 Car Video Player
Kenwood DNX7100 Car Video Player Logo
65 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
