FixYa.com
Tags:
JVC AV-20120 TV
Closed Captioning stopped working
posted by MichaelF on Nov 01, 2007
My close captioning stopped working on my TV this evening.  I did the same thing I normally do to turn it on, went to the menu button and switched back to watching TV and it didn't come on.
Comment by MichaelF, posted on Nov 03, 2007
Thanks - my remote case doesn't open - I removed the screw - no go. Regardless, the close captioning didn't work even when I tried to do direct physical input on the television. It appears to have been a cable problem - the box rebooted itself yesterday and since then the close captioning is working again. Thanks!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 01, 2007
Thanks for Trying (70)
orlyboy
Rank:Wiz Wiz
Rating: 81%, 68 votes
if close captioning doesn't work in your television,try to clean the circuit of your remote.Just open it,wipe with the use of cotton and alcohol.I'm sure it will work
Rating Locked! (?) MichaelF has rated this solution as Thanks for Trying
Can you Help with these Standard Televisions problems?
Panasonic CT-32HX42F
The tv has shut off by itself.... Answer This...
Panasonic CT 32SC14J 32"...
Hi all- I'm having a weird... Answer This...
Parental Control Lock
I bought this tv at a moving... Answer This...
SKY REMOTE CODE
i just got a lg model number... Answer This...
JVC AV-20120 TV
audio settings dissapeared from...
if i go thru the menu i have :... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
