Question about Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
The tines on my troy built Horse tiller do not grb when tilling. Are the gears in the drive shaft the problem? How do you fix this?
  • 1 more comment
  • gpecci2 Jun 17, 2009
    There is NO grinding sound when the tines are engaged. They turn easily, but just appear to slip when plunged into the ground. Can the gears be stripped and yet allow for turning of the tines when not in the ground? Thnaks for your help.
  • gpecci2 Jun 18, 2009
    You are right. I need to replace the belt, but I can't figure out how to remove the belt. Can you tell me how, please?
  • same463 May 11, 2010
    Is there a grinding sound when the tines try to catch? If so the gear box needs repaired or replaced. No noise? Is it belt or chain driven? Either could need replaced.
    Scholar:
  • 81 Answers
Since there is no grinding noise, if the problem is in the gear box it isn't too severe. There is a slight possibility that a tooth or two has been broken off one of the gears. But it sounds more like you have a worn drive belt. Most of the time when the tines don't grab or they slip it is because the drive belt have become worn in some way. If it is suppose to be a one-half inch wide belt it could have thinned to a three-eight inch allowing the belt to drop further into the pulley than needed, or it may be "sloppy", not tightening enough to operate the tines if it has stretched. The right belt is very important and is an easy fix. I hope this helps.
Posted on Jun 18, 2009
  • same463 Jun 19, 2009
    First I need to know the model number of the tiller. Not the engine, but the tiller. It's easy to remove the belt, just cut it off with a knife.
    But do you already have your replacement belt or the number of the belt? I need to look at the specs of your model to see how it is reinstalled.
  • 15 Answers
When you try to engage the tines with the lever above the left hand rear side is there any noise if you do this with the motor running and the drive unit in gear? I need more info than you have given to suggest a proper repair.
Posted on Jun 17, 2009
Troy built horse loses power when I engage tines into the dirt. What do I need to service?
sounds like you are trying to till too deep raise tines up a little with the depth gauge then till the same spot again and see if that helps
Mar 10, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Troy-bilt horse engiine runs good , tines work,
The wheel shaft on a Horse tiller is one piece so if the shaft turns on one side it will turn on the other. make sure the pin that holds the wheel on is not missing that would let it spin on the shaft.
That's the only thing I can think of that would cause that problem. Hope that helps.
Frank
Aug 29, 2010 | Troy-Bilt Garden
Tines will not turn when engeged. made a grinding
It sounds like a problem with the drive pulley on the engine to me. Maybe the key is striped.
May 27, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Old Troy Built with model #HH60-105106F. What is
That's the engine number. It's a 6Hp Tecumseh. Go on ebay and buy the Troy Bilt parts manuals on CD for Horse Roto Tillers (if that's what it's on). I paid $8. Definitely worth it.
Mar 08, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
How does the gear box come apart on a six horse troy built tiller?
  1. Remove belt guard on left side
  2. Remove belt, large pulley on gearbox.
  3. Remove throttle cable, idler pulley cable and shift handle.
  4. Remove engine, handle, wheels, tines cover and tines.
  5. Lay gearbox on side on two sawhorses, left side facing up
  6. Remove all the nuts on that side. If the three shafts have corrosion, use sandpaper to remove.
  7. Pry the two halves apart, then hammer the ends of the three shafts to push through their bushings. Use brass or wood to avoid blossoming the shaft ends. When shafts are through their bushings, the right side will fall away.
Jan 15, 2010 | Troy-Bilt Pony Garden Tiller
PTO making noise when engaged in forward drive
It's 90 weight gear oil but most likely the output shaft seal has been gone for a consdierable amount of time and has leaked out and is just now making noise, they don't normally make noise right away after the oil runs out. put oil up to the plug fill hole and watch if it runs out the shaft seal if it does then it will have ti be repaiered.
Nov 13, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
What year Troy Built Horse Tiller
The serial number is stamped on the upper right hand side of the gear housing. It is on a flat spot just above the wheel shaft. If it is a newer model it will be on a white sticker on top of the gear housing plate. If it has the T handle it is probably an older 1980's model. If you find the six digit number I can give you the year it was made.
Frank
Aug 03, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I need a new motor for horse model, serial no. 360331. which models fit this troy built.
Just about any engine with a 3/4" horizontal shaft that is internally threaded on the end and has the four bolt mounting pattern around the shaft will work. I have gone to Harbor Freight and purchased their 6.5 H.P. engine that is a Honda clone and it will work fine and only costs $100-150 dollars. The only difference is that it uses a metric bolt to hold the pulley on the shaft,the four mounting bolts are metric and you have to disconnect the low oil shutoff or the engine will die when you are tilling deep. It is a good low cost option for the Horse tillers.
Frank
Jun 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy bilt pony left side tine assembly fell off
sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
Apr 23, 2009 | Troy-Bilt Pony Garden Tiller
Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766 Logo
275 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
