Question about Fellowes ShredStik Shredder
Shredstik by fellowes
How can I sharpen the shredder, must be getting old as it only likes one sheet of paper now.
fellowesrep
  • 102 Answers
SOURCE: Fellowes Shredder keeps running
You should be able to flip up the cd cover and visibly see the sensors in the center of the paper entry(look like little LED lightbulbs) Clean with a Q-tip dipped in rubbing alchohol. This should solve your problem. If it doesn't you probally have a burned out sensor. call 1-800-945-4545 to check with customer service.
Posted on Feb 22, 2008
SOURCE: Shredder won't shut off after paper goes thru
Have the DS-12C / 32080 also. After a moderate amount of shredding it will just keep running. Sometimes it will be in the auto position and not running (waiting for paper to be inserted), and then for no apparent reason it will just start running (like in the middle of the night) no doubt this is due to dust collecting. Q-tip with alcohol works best for me over compress air. Actually the Q-tip is perfect size to thoroughly clean the sensor (which I believe is in the middle of the unit). But since I don't want to freak out at 3AM in the morning I generally leave mine off.
Posted on Mar 16, 2008
SOURCE: Fellowes PS-70 Shredder jam
I used needle-nose pliers and regular pliers to pull out all of the jammed paper -- it took an hour but I finally got it. I never did find a release mechanism even after I took the top apart. Thanks anyway!
Posted on Jun 14, 2008
dlundmark
  • 797 Answers
SOURCE: Fellowes Shredder Parent Part # 38605
If this unit is worth it to you, you can build your own gear.
Here is a link to get plastic repair materials to make plastic parts. This site also will have materials for repairing plastics.
Another possibility is to search Ebay for a unit like yours which has other problems. Never can tell... it may be there.
Make sure you ask for the model of the unit in your search (on the NET as well. The serial in this case is not needed.
Posted on Jul 26, 2008
SOURCE: Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Posted on Mar 05, 2009
CAN THE BLADES ON A FELLOWES 99Ci SHREDDER BE SHARPENED?
I do not believe so. Never heard of sharpening one. The shredding blade is pretty complicated. The manufacturer has a good support web page I suggest contacting them. Keep it clean and oiled and it should last a long time. And do not shred stuff listed on the cannot shred list.
Feb 06, 2015 | Fellowes SB-99Ci Shredder
Yellow light comes on
Look at the manual in the link below. If you do not find the answer, call Fellowes.
Fellowes Shredder Manuals
Sep 18, 2014 | Fellowes FEL-3011001 DS-1 Light-Duty...
How do I fix my blades on my shredder?
Try running a layer of aluminum foil between two sheets of paper. See if it shredds, If it does, do it a couple of times, then use shredder oil. It might help to both sharpen the blades, and to keep them sharp longer. It works on cutting blades for scrapbooking cutters and scissors...
Aug 18, 2014 | Shredder Secure Shred Shredder
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Our C220c shredder does not shred, motor turns and blades turn but i think the blades are blunt. Can you get new ones or have the old blades sharpened?
There are 2 shafts that have the cutting blades on them and they both should turn. I have replaced many gears on this model and suspect that a gear is broken. Fellowes does not have many parts this model anymore. I would call a local shredder repair service or you can call Fellowes at 800-955-0959.
Sep 11, 2013 | Fellowes 220C-2 Shredder
Ativa CX10B shredder starts but as soon as the paper goes in a short distance, it quits! It will reverse but only make it through a sheet by turning to off position and wait 3 seconds and then back on. ...
Have you run oiled paper through the shredder? If not you need to do so. Office depot will sell you the oil and tell you how to use it.
You can also hand feed a sheet of paper until it trips the paper sensors. Don't let the paper get into the cutters and let the machine run until it clears itself.
If the shredder is old (over a year old) your motor may have bad bearings. Is it noisier then usual. If so the bearings are shot.
If they are shot and you are out of warranty you are out of business. This is chinese junk and so far I have been unable to find parts.
Hope this helps.
Nov 30, 2010 | Fellowes Cross-Cut Shredder
My royal ag10x cross cut shredder is losing steam - labors thru 4 pages at a time and i've never done any maintence in 8 years. is there a way to sharpen the blades?
May not be the blades that need sharpening.....try putting some lightweight shredder oil on a sheet of paper then shred the sheet of paper....do this 2 or three times and see if it helps. It won't hurt to put a good bit of oil on the paper.
Aug 30, 2010 | Royal Office Equipment & Supplies
Fellowes Powershred PS 60CC stopped working
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Jan 14, 2010 | Fellowes Powershred PS-60 Shredder
Fellowes p45C
Please call us (Fellowes) at 1-800-945-4545 to check and see if this is a warranty issue or if we can troubleshoot the machine for you. It sounds like you may have a gear that went out
Mar 18, 2008 | Fellowes 3011001 Shredder
67 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
