Hi you can remove the PC Perfomer using the software Ccleaner. CCleaner 4 09 4471
select tools and uninstall the PC Performer, if it doesn't uninstall then select delete entry. Also Ccleaner makes your computer faster by removing temporary files/cleaning registry. Hope this helps.
The best way to speed up a slow running computer is to clean it for viruses. Also optimize your system, browser and registry using some reliable cleaner such as Reginout Cleaner.
If your experiencing a slow computer performance, what you can do is to delete some unwanted files and folders and remove all the unwanted programs on the computer. After removing files and programs, run the Disk Defragmenter application on your windows as it will help optimizing the performance of your computer.
- click start > all programs > accessories > system tools > disk defragmenter - click defrag
To remove programs, go to control panel > programs and features / add remove programs > uninstall
You may want to look into upgrading your RAM if there is less than 2GB installed. This is a recommendation that I have found in working with several PC's running this Operating System. Also, you would want to run disk clean up and remove any temporary files that Windows finds. Deleting any other temporary or unused files from your PC on a regular basis should increase system performance. In addition, if these steps do not solve your problem, you may want to consider upgrading to a faster performance hard drive (preferably a SATA II with a 32MB cache). As a last resort, you may look at your CPU to see if there is an upgrade for it, as well. Keep in mind that Vista is a resource hog and can slow down a PC within just a short period of time.
the problem is u have a lot stored on the pc memory and when this are much it slow down your computer so what u need to do is check your desktop and delet some things u no longer needs or dont open too much pages on your home page this can make your pc slow down ok,thnks .
Well, there are quite a lot of causes for your running slow or freezing MacBook
computer, if you prefer a quicker yet easier way to fix the performance
issues, see here: http://www.speedupmacbook.com/
