Question about Epson Stylus C88 InkJet Photo Printer
Red light blinking, how do I determine which cartridge needs replacement?
Please tell me how to determine which cartridge to replace? I can't find my manual.
Thanks very much..
  • Epson Master
  • 1,113 Answers
Open lid with power on, carriage should move to left and stop look where it stops on area behind carriage there is a triangle that points to a spot on carriage indicating which ink need attention
Or there is a status monitor that comes with print driver that tells you on computer
Posted on Nov 01, 2007
I have a Epson Stylus printer and the red light goes on .What does that means????
red light usually means a device error or failure.
check the basics like the cable , paper jam (open printer top, front, side covers and check for debris like paper clips, small piece of paper, etc.), also make sure that the cartridge is not improperly installed re-install cartridge and make sure the cartridge/s are installed properly you should hear a click noise when cartridge is properly installed), printer cover may also be not properly closed.
also, check that printer is supported by the computer's operating system. you may need to download and install the printer's latest software/driver for the computer's operating system.
Mar 01, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have cleaned the print heads, replaced cartridges and still can't get text to print. Any idea?
If you have a a solid red light showing you will not get any printing done. On the epson printer which red light is showing? Is it the one for the black or the color? Was that cartridge replaced by you? I have actually seen one cartridge's red light glowing and so replace the cartridge. Then the printer goes through a charging sequence and to my surprise another red light is showing, but this time it's the other cartridge, because the printer was already low on that color and the charging cycle emptied that cartridge enough to trigger the light to start blinking on and off. Now suppose it's the same light that is still on even after you replaced the cartridge. Do this: hold the paper in feed button for about 3 seconds. The printhead will move to the left. Lift up the clamp of the cartridge that
has the red light glowing and bring it down somewhat definitively again to lock the cartridge down. There is a microswitch that is reset when this is done that tells the printer it has a new cartridge installed. Sometimes when a cartridge is replaced the switch is not reset if the clamping process is not definitive enough, or it simply needs to be done again. When you've done this push the paper infeed button again to move the head back to park postition.
Good luck,
Jan 05, 2011 | Epson CX4200 All-In-One PSC Printer
Red light blinking
yes, you have to replace toner cartridge. If the problem persist just vizit autorized service!
May 22, 2010 | Samsung ML-2510 Laser Printer
Red and green lights are blinking, doesn't go away when restarted
All lights blinking is indicative of serious ink issue. This could be as a result of a number of scenarios.
i. Ink has developed incompatibility. Solution is try an older/another cartridge (doesn’t matter if ink is finished). If it stops blinking it confirms that your cartridge has become incompatible. Also if your printer is the type that can work with only one cartridge, remove one after the other to determine which in the set (black or color) has become incompatible. Just replace the incompatible one and start printing again.
ii. The electronic panel on the cartridge that contact with the cartridge carrier inside the printer is dirty and needs cleaning. Solution is try to clean with a piece of folded tissue paper soaked in a bit of methylated spirit. Also clean where the cartridge carrier where t makes contact.
Dec 04, 2009 | Office Equipment & Supplies
Says replace ink cartridge
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have disconnected the usb and the power. I have only had this printer for about a year. It won't scan or print. Its a Kodak Easyshare 5300. The HomeCenter AiO is disconnected so how do I contact anyone from Kodak?
Feb 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I am using a hp 4360 printer-I do not have a manual-
I'm not fully understanding what lights are flashing. Here is a link to the manual that you can determine what the light pattern means. Copy and paste this line into your address bar:
Feb 23, 2009 | HP Office Equipment & Supplies
Blinking red and yellow light
Generally if both the (red) alarm LED and the (yellow) data LED are both blinking, it is an indication that the tone cartridge needs to be replaced. You should be close to out of cartridge.
Jan 12, 2009 | Brother HL 1440 Laser Printer
Blinking red light
Red Light blinks when the ink cartridge is bad..
to check which one is bad..
take out all cartridges from the printer and clean the copper contact and the inner area of the cartridge slot with a lint-free cloth...
power off the printer and unplug the power cable from the printer..
press & hold the power button on the printer for 60 seconds..
connect the power cable and power on the printer..
insert any ONE cartridge and close the door..
similarly insert other cartridges one by one and close the door and check if the light blinks..
if it blinks means the respective cartridge is bad and replace it..
if u have replaced all the might be possible that the cartridge sensor inside the printer have gone bad..
if this is the case so ..u might service the printer..
but I will suggest to go for a new printer as 7660 is quite an lod printer which hp launched in 2004 or 2005..
even if u have juz bought it will be refurbished one..
Aug 12, 2008 | HP PhotoSmart 7660 InkJet Printer
no, I have paper....the red-light on the top keeps blinking.....
I have used akums-razor to determine the answer.....
sol: push and hold down the orange button for 3-4 secs and wait for a print-out. It will give you the staus of the toner cartdg. MINE REPORTS A LOWWWW LEVEL. ( the orig. cartridge gives the user only about 1000 sheets and mine is around 783. This is why I think the light came on to tell me to jump in my Lexus, get down to Best Buy, and get another ( more capacity) new cartridge....
cool, huh?:>))))
May 09, 2008 | Samsung ML-2510 Laser Printer
Printer not working
Red inkout1.jpg ink light flashes One of the cartridges is low on ink. Check the message that appears on your screen to determine which cartridge is low or follow the instructions in Checking the Ink Supply. Make sure you have a replacement cartridge.
Feb 12, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus C88 InkJet Photo Printer Logo
96 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
