Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Was running fine and just quit..checked it and found no spark
  • 1,040 Answers
Assuming the spark plug is good, it is probably the ignition module.
Jim
Posted on Jun 17, 2009
  • Jim Parker
    Jim Parker Jun 21, 2009
    Did this solution solve the problem?
    Jim
98 Chevy 1500 Running down road dies Has fuel. Has spark.
If it has spark to the plugs, normal compression, and fuel, it should start. So assuming it does have normal compression, I would want to know if it will try to start by spraying carb cleaner into the throttle body to substitute the injector spray. One of the three components is missing.
Another thing to check is the distributor cap and rotor to make sure spark is reaching all of the plugs at the right time.
Aug 31, 2014 | 1998 Chevrolet K1500
No spark the engine
how do you know its no spark..
Dec 22, 2013 | 1991 Pontiac Firebird
No spark
Mag. failure on husky`s is quite common, l had a similar problem with my husky chainsaw.l would on your`s try another spark plug first then check the mag....
Dec 31, 2012 | Husqvarna 28cc 2-Cycle Curved-Shaft Gas...
Engin runs fine for about twenty minutes then quits. oil level is full
try and run it with a loose gas cap the vent could be clogged then check for spark when the engine dies or even better get a inline spark tester then you can see it when its dieing
Jul 12, 2012 | Garden
Blower cranks easily and runs fine for about 1 minute and quits. I have cleaned the air filter and changed the spark plug but no luck. Any suggestions would be appreciated?
run it till it quits. pull the plug wire and check to see if you still have spark when pulling it over. if no spark replace the ignition module. if you still have spark then your fuel tank may not be venting. loosen the fuel cap enough that you know its venting and try running it again. if problem solved replace check valve and or fuel cap. hope this helps you
Aug 16, 2011 | Husqvarna 952711918 Leaf Blower Gutter Kit...
My stihl chainsaw has been running great in the past years
try this. all stihl machines have a fuel filter on the end of the fuel line inside the tank. if you get a hooked peice of wire you can hook it out through the petrol filler cap. these are very fine and may not looked blocked. you can remove the filter element from its holder to clean it. you can also try the saw without the filter for a short time to see if this is the problem.
Sep 07, 2009 | Garden
Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Onece in a while turn over wont fire. runs great other wise
your injector or fuel pump may be going out, next time when you check the issue, check your distubutor again and making sure you getting sparks, if you do have sparks than it has to be your fuel problems.
Jun 25, 2009 | 1991 Honda Civic
No spark when hot 84 goldwing
hay there i wood have a look at the ignion coil frist then check the pic up coils these have that afect wen faulty . next id be look ing at the igniter box but these are a bit hard to test
May 31, 2009 | 1985 Honda GL 1200 Interstate Gold Wing
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
198 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
