Question about Acer Aspire 3003LCi Notebook
Laptop doesn't power on.
I left laptop on without being plugging it up, of course the battery died, but now when I plugged it up, when I push the power button, only the little yellow battery light flashes, does this mean I need to let it charge up before I use it again or do i have a serious problem?
    Scholar:
  • 127 Answers
Try to let it charge for a few hours and turn it on again. Note: don't let your laptop discharge the battery this may damage the battery cells.
Posted on Nov 01, 2007
Hi, I really need some help. I want to know whats wrong before taking my hp pavllion dv600 to service centre. Problem is that the charger doesn?t charge the battery at all. Charger is fine with other...
If the power supply does not run the laptop without the battery, then the problem is the jack in the laptop, over time the plug breaks free of the motherboard causing intermittent operation or no power. If the power supply runs the laptop without the battery, it is the charging circuits on the motherboard that is the issue.
Jan 04, 2011 | Computers & Internet
I try to turn on my laptop, and it won't turn on. When it originally happened I was on it, without the charger plugged in, online. It was working fine, and then all of a sudden it shut off, and will no...
Your battery is probably completely discharged. This can prevent the laptop from starting even WITH the power plugged in. You might try removing the battery, then plug in the AC power adapter. Push the power button and HOLD IT down for 30 seconds (your laptop may or may not start up. If it starts, then shut it down normally.)
Replace the battery. With the AC still plugged in, repeat the start proceedure above. Leave the laptop on until the battery is fully charged. If this doesn't work, then your battery may be bad (this can happen all at once) or worse, your charging system isn't working (less likely.) Your power adapter could also be bad - is the green light on when it's plugged in?
You may have to repeat the proceedure a few times before it works as the battery needs to show a little charge before it will start.
Once started, press F2 while on the dell logo to go to the setup screen. Select the power options. and you should see if the battery is detected. If battery is detected, it should say "charging".
If none of this works, call Dell technical support 800 822-8965 for further assistance
Nov 29, 2010 | Dell Inspiron M5030 Laptop
I have an IBM T40 that worked great until yesterday. When I powered it up, the 4 lights (battery, etc) flickers but the laptop does not power up. I removed the battery, paused, tried with and without the...
There are a few things left you can try. First take the battery out and make sure the unit is unplugged. Next push the power button a few times to discharge any power inside the unit. Now put the battery back in and while plugging in the unit see if the charge light comes on or flickers at all.
If it flickers and goes out, you have a bad power cord or worse a bad jack on the laptop's main board. If it never comes on, you have a bad power cord or mainboard. The battery is probably dead (doesen't have a charge left in it.)
You said this happens regardless of if the battery is inserted. Have you tried powering up the unit with no battery installed and just the power plug?
I'd see about gettting a replacement cord first. If that doesen't do it you probably have a bad board.
Oct 17, 2010 | Computers & Internet
My HP 3210 all-in-one printer does not power up when I plug it in. It appears to be getting power because when I plug the printer in, the little bluetooth light in the front lower right does light up. ...
Are you taking it off electricity a log? If so you have to set it up to your preferences sometimes. And are you tapping the "on" button at far left at the top? It should work. But it must be plugged in of course and the button has to be pushed. Don't push too hard or too long or it will turn off.
Aug 06, 2010 | HP Photosmart 3210 Printer
Gateway MA7 (MX6955) Will not boot up, or power on. Battery and AC plugged in battery LED light flashes 4 times and nothing... battery in AC unplugged.. same thing... battery out, AC plugged in.. nothing,...
hold on i have a gateway here let me see if it does or not.nope mine works without battery i had to push the power button a couple times but it fired up.could be your MB
Oct 08, 2009 | Computers & Internet
My music is d.o.a.!
my wife had just pushed the little reset pinhole button thingy and it started functioning properly
Jun 04, 2009 | Samsung YP-T10 Digital Media Player
My compaq presario c500 doesn't respond to the start button
try to turn on the laptop without the battery and only the power cord plug in.
if your laptop works with this you need new battery or update bios ( there might be fix for battery monitor)
if not, call service support, might be motherboard issue
let me know an update
Apr 03, 2009 | HP Compaq Presario C500t Notebook
Not starting
Just to sum it up, are we talking about the Dell Inspiron 1750 or a Dell Inspiron 6000? Seeing two different things here. With the regards to the ac adapter, How "Warm"are we talking about here. 1 to 10. "1" 100 below 0 or "10" Nuclear Reactor Hot? Any adapters can get warm to the touch without overheating and frying. Was there a blackout or power outages in your area or T-Storm on the day you left. Take off the battery from the laptop. Check the battery lights. Do they flash or do they all light up when you press the button. With the laptop not working, lets hope the battery didnt fry the mainboard. Have you try to fire it up again after the adapter has a chance to cool down. By now, it should be fine, if you haven't use it.
Let me know
comier957
Aug 10, 2008 | Dell Inspiron 6000 Notebook
No power on
cheak the all battery points.
Jun 10, 2008 | Compaq Evo N610C Notebook
Acer Aspire 3003LCi Notebook Logo
85 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
