Question about Gateway CX200X Tablet PC
CX200X worked fine yesterday, now I am unable to turn the power on to the laptop. I have power through the adapter to the connection to the computer. I have a full battery charge light indicator. When I push the power button nothing happens. This occurs with the battery attached or just operating on wall power. Could the on/off switch just go bad? Solutions since I can't find a good manual to facilitate personnal repairs?
Make sure the power lock button on the lower righthand side is in the UP position.
it locks the computer into the OFF state if it is switched DOWN after powering down.
Posted on Jun 18, 2009
  • 255 Answers
contact nearby service centre.....this problem might be your charger problem... or powersection problem inside the computer..
regards
ehsanullah.
Posted on Jun 17, 2009
Laptop hp compaq tc 4400 is not charging , during adapter connected to laptop and turning power/standby led ... it doesnt switches on, instead battery charging led blinks 4 times, and doesnt turns on, so...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 16, 2011 | Compaq tc4400 Tablet PC
My laptop is not turning on. I recently purchased a new battery and ac plug. Everything worked perfectly for about two weeks. It worked fine in the morning but when I tried to turn it on for lunch...
1. Check ur Power Adapter, whether ur laptop get power or not.
2. if power cable and adapter ok. check system RAM
but u said it does not recognize power, So u have problem with either Power card or power plug inside laptop. and u said it deosn not recognize battery also, in this case check RAM, CPU and MB.
DO VOTE
Sep 24, 2010 | Compaq 2710p Tablet PC
Ram for gateway cx200x pls
please login to http://www.mundocorp.com/gateway-laptop-parts/
Sep 08, 2010 | Gateway CX200X Tablet PC
Computer had a bug, which I have now cleaned. The cd/dvd not work
cleaning it with spybot does not really clean your computer all the way. try to get reformat that way it will uninstall and reinstall the drivers for your cd drive. also, that would get rid off the bug totally from your computer. let me know how it goes
Jun 15, 2009 | Gateway CX200X Tablet PC
Lenovo X60 laptop display has stopped working
The backlight is broken. These are small flourescent tube lights about the width of a pencil lead. You dropped the laptop and the bulb broke. It will have to be replaced. The driver has nothing to do with your problem, reinstalling it will not get your picture back.
Dec 13, 2008 | Lenovo ThinkPad X60 Tablet PC
Laptop won't start up
Same thing for me 17 months old and normal usage
Dec 01, 2008 | HP Pavilion tx1220us Tablet PC
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
Fujitsu laptop, touchpad stops working when connected to power adapter
dear
the consumption power ampere is symptom to your voltage of touchpad
trying installing driver touch pad again
and try to use FN + F9
oke
cropp
Mar 09, 2008 | Tablets & eReaders
No power up
Are you sure that the lock button is completely in the unlocked position? If so, once this happened to me, and I removed the battery for about 5 minutes, then reconnected it and the computer powered up.
Nov 12, 2007 | Gateway CX200X Tablet PC
Gateway CX200X Tablet PC Logo
367 people viewed this question
Top Gateway Tablets & eReaders Experts
Ricky Ostrom
Ricky Ostrom
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
