Question about Visio 5.0 Professional Upgrade (11770-0198) for PC
Can't load Visio 4 on computer with Windows XP
Setup will not strat the process of loading Visio with XP
  • 23 Answers
And it wont either because xp can read the program files of visio because it needs vista ok
Posted on Jun 19, 2009
How to format for windows xp
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key but will differ depending on your computer and Bios.
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system.
Note: After you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
If you are putting windows XP on your computer your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd\dvd.
Aug 15, 2013 | Computers & Internet
Add/Remove Window components
Im not sure which file you are referring to but you could just a repair of the installation
this is fot the master boot record
if there are any other files , settings or programs during the repair process options for these should be available
Insert your Windows XP installation CD or recovery disc, and restart the computer.
Instead of attempting to boot Windows as it normally would, the computer will give you an option to boot from the CD.
Press a key when prompted, then wait for the setup program to load.
Press the "R" key on the "Welcome to Setup" screen.
This will cause the CD to launch the Recovery Console instead of attempting to install Windows XP on your computer.
If you have an administrator password on your copy of XP, then you will need to enter it in order to log in to the Recovery Console.
Choose the installation of Windows XP that you want to repair (generally the only option). Wait for the command prompt to appear, then enter "fixmbr." Press "y" when prompted to let the FixMBR utility overwrite the corrupted bootloader with a new copy.
Remove your XP disc or recovery disc, then type "exit" into the command prompt.
The exit command should cause the computer to reboot, allowing the computer to load the new bootloader file and then continue Windows XP startup as normal.
Hope this helps
Oct 30, 2012 | Microsoft Windows XP Professional
Lenovo stuck on loading page, and wont enter safe mode
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Jul 14, 2012 | Computers & Internet
Windows xp start up disk doesn't work
if you are referring to the installaion disk
restart your computer during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
hope this helps you
Apr 16, 2012 | Computers & Internet
How do I reformat my harddrive using widows xp
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
Hope it helps you
Apr 11, 2012 | Microsoft Windows XP Home for PC
My Dell 2400 refuses to load windows xp
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
Hope this helps you
Oct 31, 2011 | Dell Computers & Internet
Asus k8n-e when xp strat loading the sytem reboots automaticaly
There are two Asus K8N-E MB models;
http://www.asus.com/Search.aspx?SearchKey=K8N-E
Chances are there was a problem during the installation of windows XP. Or there is an issue with your hard disk drive. During boot up, press the F5 key every 2 seconds. Windows Advanced Option Menu will load. From the list highlight, Safe Mode with Command Prompt & press enter. Type the command, C: space fixmbr & "press enter". Wait a few seconds for fixmbr to run.
Than press ctrl+alt+delete to reboot your system. If windows still restarts you will need to reinstall windows XP. A Fresh install is preferred. Running windows repair can make matters worse. Every hard disk drive manufacture has software to setup their drives. Example: If your hard disk drive is made by Seagate, go to Seagate’s web site & download their setup software. Download SeaTools for DOS now!
http://www.seagate.com/www/en-us/support/downloads/seatools/
Instructions are included on the site.
Here is the link for Samsung; http://www.samsung.com/global/business/hdd/
For Western Digital;
http://support.wdc.com/product/download.asp?lang=en
Use the manufacture’s software to setup your hard disk drive before installing Windows XP.
Cheers!
Mike
Oct 07, 2009 | ASUS K8N-E Motherboard
I want to know my Administrator Password
Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD) 2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
Feb 26, 2008 | Microsoft Windows XP Professional With...
Installing windows xp
Try first  to use hiden boot cd.With it u can see all files on hdd.When u see winxp files just delte.But i will not take responsibility couse sometimes xp wont boot up...
But i recomneded you to save all your data and format your pc.Make sure that the partition cd must be deltet befor u contiuing with formating ur pc like in this pics:
http://www.imagehost.ro/pict/3003390347268b3728923.jpg
Oct 29, 2007 | Microsoft Windows XP Home Edition
Visio 5.0 Professional Upgrade (11770-0198) for PC Logo
236 people viewed this question
Top Visio Computers & Internet Experts
Vebble
Marvin
Marvin
Moazzem Hossain
Moazzem Hossain
Are you a Visio Computer and Internet Expert? Answer questions, earn points and help others
