Question about Dell Dimension 3100 PC Desktop
Microphone not working
Microphone stopped working after a tech fixed an email issue. Used microphone with skype program. checked in control panal. microphone show that it is not working.
  • 8 more comments
  • henryup39 Jun 17, 2009
    I will attempt to apply this solution, it will take me some time, will proably have to sign on again tommorrow after writting down the solution. Assuming that is possible to come back into the fixya program. thanks
    every thing appears in order but still does not work.
    One of your links just gives an advertisement on music down load, no thanks for the help. I would not know how to down load drivers. Why ? the system worked before a tech adjusted something. No thanks, I will move on.
    Want down your list and attempted all, no changes. These directions are over my head. thanks for the try.
    Sorry I would not know how to manupulate drivers. these directions are way over my head as well as is how to use this sight.
    Your directions were great, but a screen finaly came up and said, "Does not support this application," or something close to that. My laptop and desktop worked fine with Skype until a tech worked on my email sites problems, which was bringing on msft outlook email. The tech is not answering my calls about this.
  • henryup39 Jun 20, 2009
    At this time only a speaker symbol appears in the bottom tray, Althought it was there previously, before I tryed fixing things on my own. How to get it back? I did not figure/find out how.
    My mic is a head set by logtech as recommended by Skype. This head set worked fine until my system was worked on.
    Also using window XP
    i PRINTED your directions and will work on applying them. It will take a couple of days. Thanks
  • henryup39 Jun 25, 2009
    i HAVE DONE EVERYTHING THAT YOu suggested and that I understood.there is no change. i am giving up on this, Thanks for the effort.
    President:
  • 1,952 Answers
Windows with the latest Service Packs and updates, available from http://windowsupdate.microsoft.com/
• Device (sound, video, motherboard etc) drivers (those can be found on the device manufacturer's website - contact the manufacturer/vendor of the device for more information)
• DirectX - the core multimedia component of Windows. The newest version can be found at: http://www.microsoft.com/windows/directx/default.aspx
After that please reinstall Skype as follows:
1. Backup your Skype chat history files.
• Close Skype
• Go to C:\Documents and Settings\your_windows_username\ApplicationData\Skype\your_skype_name
and copy this directory somewhere safe (burn to CD, etc.)
2. Uninstall Skype.
• Open "Control Panel" (Start > Control Panel, or Start > Settings > Control Panel) and choose "Add/Remove Programs".
• Select Skype from the list and click on "Remove".
• Go to C:\Program Files and delete the Skype folder from there.
• Go to C:\Documents and Settings\your_windows_username\ApplicationData and delete the Skype folder from there.
• Go to C:\Documents and Settings\All users\ApplicationData and delete the Skype folder from there.
• Open “Windows Start Menu” and select "Run".
• Enter "regedit" in the text box and click "OK".
• Open the "Edit" drop-down menu and click "Find".
• Search for the keyword "Skype". Delete all search results.
3. Download and install the latest version of Skype at:
http://www.skype.com/go/download
4. To restore your chat history, move Skype chat history files back to:
C:\Documents and Settings\your_windows_username\ApplicationData\Skype\your_skype_name.
Note: There is no need to backup contacts as they are stored centrally on our server and can be accessed anywhere as long as you log in with the same username and password. A detailed list of your calls and SMS messages is available at:
https://secure.skype.com/store/myaccount/history.html
Hope this helps.
Had to uncheck Skype option "Let Skype adjust my sound device settings"
Skype was setting microphone back to wrong settings when I went skypping.
Posted on Jun 20, 2009
  • mohammed marika thambi
    mohammed marika thambi Jun 20, 2009
    Audio settings, in Windows and Skype
    XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
    or Right-click speaker icon in system tray and select "Adjust Audio Properties"
    Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
    Volume
    / Device Volume / Advanced: If there is no “Microphone” section in this
    window, go to Options / Properties and check “Microphone” in the
    “Playback” list. Then make sure “Mute” IS checked in this window
    Audio / Sound Playback: Your on board sound/Sound Card
    Audio / Sound Recording: Your on board sound/Sound Card
    Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
    Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
    Volume
    Skype / Tools / Options / Audio Settings:
    Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
    Speakers: Your headset, USB device or speakers, as you prefer
    Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
    Note:
    The audio devices you want to use MUST be present in these Skype device
    lists. If they are not, check the device connections and driver
    installations again.
    2. Microphone and Speaker connections
    Check if your mic (pink) and speaker
    (lime) jacks are in the proper sockets (it is easy to reverse them) and
    fully inserted (they sometimes stick only partially inserted)
    If your microphone or headset has a “Mute” switch, make sure it is not on
    If your speakers or headset has a volume control, make sure it is turned up
    For
    test only you can use an earphone instead of microphone (really)! Just
    unplug the microphone, plug the earphone into the microphone jack, and
    talk into your earphones. (I know it sounds silly, but it might tell
    you if your microphone is defective)
    A standard microphone plugged into Line In will NOT work.
    3. Check audio in Windows.
    XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
    Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
    Make
    a short recording with the microphone; you should see the level meters
    moving as you speak. On Windows XP, you can then play back what you
    recorded.
    double click on the sound icon by the clock at the bottom toolbar
    make sure that none of the things in there are "muted"
    that was my problem after i accidently pluged my headphones into my computers mic jack.
    it auto mutes the build in one if you do that
    mike is muted again.. I can't dl attachment you posted, it takes me to http://forum.skype.com/index.php?act=att..., which is a blank pg..
    pressing mute button again and again wont un-mute mike, and the button doesn't change, it always stays in "muted" icon..
    Warning
    you must remember your Skype username and password before you do this
    otherwise you will not be able to log in when you restart Skype because
    the link to your username and password details will be lost when you
    delete config.xml and all options are reset to default. You are also
    advised as a safety factor to backup your contacts list by going to the
    Main Skype window>………Tools>…….advanced>……..Backup contacts to
    file. This will save a yourskypeusername.vcf file to a location on your
    PC of your choice.
    First logoff Skype and shut it down.
    Start
    Run
    Type:%appdata%
    Now look for the Skype folder.
    Open that folder and look for another folder with the same name as you Skype username.
    In this folder you will see the file config.xml
    Rename this file to config1.xml.
    Re-run
    Skype and log in with your data and a new config.xml file will be built
    and all you contacts should still be shown on you contacts list if this
    is not so you can always reverse what you have just done and nothing
    has been lost.
    If doing this first step does not solve your
    problem this time when you open the Skype you need to look for the file
    shared.xml. Do the same to this as you did to you config.xml file.
    Re-run
    Skype and log in with your data and a new shared.xml file will be
    built, if this does not solve you problem you can always reverse what
    you have just done and nothing has been lost.
    As a very last resort:
    Exit Skype
    Start
    Run
    Type: %appdata%
    delete folder "Skype".
    Re-run
    Skype and log in with your data. the Skype folder and both the config
    and shared.xml files will be rebuilt when you restart Skype as it could
    be a problem conflict in both files that is causing your problem and
    you will only find this out by deleting both files.
Hello henryup39
I really want to help you with this.
I understand it was working before but please confirm the following for me:
  • What operating system the computer is running (such as Windows XP, Vista, etc)
  • The make and model of the microphone (may be written on it somewhere)
Along with that, please tell me the following:
  1. Right-click on the small speaker icon in your system tray (that is next to the time in the bottom-right) and choose Recording Devices
  2. What do you see listed in the Recording Devices tab?
I should be able to assist further. Please get back to me.
Best regards
nLinked
Posted on Jun 18, 2009
    President:
  • 1,383 Answers
For that you have to uninstall old sound drivers from computer then install again.
I also have this issue in my dell laptop sigmatel drivers.just uninstall and then install from here.
If you havent drivers then download from here.
Just select your operating system and downlaod from here.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_3100&os=WW1&osl=en&catid=&impid=
Posted on Jun 17, 2009
  • kishor
    kishor Jun 17, 2009
    First scan your computer woth updated antivirus.
    Also remove aalication related sound .from add remove program then install it again.
  • kishor
    kishor Jun 17, 2009
    just clik on this link
    Tehn select your operating system like winxp or vista
    then clik on + sign in audio then u see sigma tel on second line then clik on download now then install in computer.
    Please rate my solution If you want to appreciate me .
    Many
    Thanks
    Kamal
  • Dell Master
  • 1,800 Answers
Hello.
1. Audio settings all versions
Skype:
Skype-->Main window…..>Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard (AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
2)Check if your micro (pink) and speaker (lime) jacks are really correct and fully inserted!
They sometimes stuck.
For test only you can use earphone instead of microphone for Line In.
Standard micro in Line In will NOT work.
Go to:
Start
Programs
Accessories
Entertainment or go to
Volume Control; right click on loudspeaker icon in Task Tray
Options
Microphone
Scroll down
Check "Microphone"
If the bar "Microphone" is available, the microphone is detected by Windows now go on
(If not, Windows has a problem with your microphone)
Just to check if your microphone is broken or bad, you can use your headphones instead. They really work!
Which one L or R is microphone now, I think it's L
Check "Advanced properties"
Check Micro "Advanced"
Open
Check "20db boost" or "1.MIC boost" depending on language version
Volume level can be left in any position.
Mute microphone!!!
3. Check audio now on windows base.
Start
Programs
Accessories
Entertainment
Soundrecorder
4. Once done, test with Skype Test Call echo123.
Good Luck
Please Vote.
Microphone doesnt work with skype
I've heard of this problem alot, I took 10 minutes today with my friend with this headset to figure out a fix.
From what i can tell, Skype doesnt pick up the Microphones input.
The only solution I could figure out so far has been this.
A voice changing program called MorphVox Pro (by Screaming bee) offers a Trial.
If you download it, and set up your microphone on this to work, You can then in skype select the MorphVOX Pro as your microphone, and you can use this chat program to work with your headset.
This is only a temporary fix But it is a step in the right direction, I'll be forwarding my email to Razer later to try and get some updates for the headset.
Best Regards
Ricky.
Feb 09, 2013 | Razer Chimaera 5.1 Wireless Gaming Headset...
My chrystaleye webcam wont work with skype
SKYPE VIDEO PROBLEM
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub. SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Sep 03, 2012 | Acer Aspire 5500 5570-2609 Laptop
I CAN SEE OTHER PERSON AND THEY CAN SEE ME BUT CANT HEAR ME BUT I CAN HEAR THEM .WHAT HAVE I DONE WRONG
The problem is either the microphone is not connected/faulty or the wrong microphone is selected in the Skype Audio setting.
To check if the microphone is working - go to Start - All Programs - Accessories - Entertainment - Sound Recorder and do a test recording.
If the sound is doesn't work then open Device Manager - Sound, video and game controllers and check the microphone is enabled and working. If it isn't listed or has a yellow ? against the microphone then you need to install the microphone device driver.
If the microphone is working then open Skype then click on Tools tab -then Options - Audio Settings - then in microphone setting and click on the microphone list to select your model microphone. Then Save your settings.
To test your microphone settings then go to Contact list and select Echo / Sound Test.Service and follow the instructions. If this works then your friends will be able to hear you,
Nov 07, 2009 | Logitech Quickcam Chat Webcam
Since it was working fine>Try to perform system restore >If that does not fixes the issue.
Check the Micro phone with the diff unit to check whether its healthy or not>If the mic working fine with the diff unit. It could be some thing with some settings.
If the Microphone not working on diff unit as well>OF course its an issue with MPhone
Jul 03, 2009 | Computers & Internet
Microphone used with skype program stopped working after technition fixed email issues. He has no idea why
Hi
Try changing your sound mode in skype from ALSA to OSS (I know OSS isn't great but skype likes it more, ALSA support is still new). Then close any other application that could possibly be using sound, and restart skype.
The major problem with OSS is that it allows only one program to access the sound at any time, which is probaby why your audacity isn't detecting the input either - there could be a setting somewhere set to oss. SO just try closing everything like I've said above.
If it still does not work then First go to tools-->options-->sound Devices-->(UN) tick, Let Skype Adjust My Sound Settings.-->save
Reboot/Restart SKYPE i.e Log Out and Back in USING your password.
With AGC disabled you can monitor AND ADJUST the microphone level DURING A VOICE CALL using windows recording sound properties. Just drag the slider up or down for best volume without clipping. When the call ends the NEW setting that you just made manually is written back to shared.xml and will be used for the next call.
Attention: MS sound recorder will NOT do this job
Save
Retest and see if its OK.
If not do below:
Enter:
%AppData%\Skype\ in the address bar of Windows Explorer and it will display all files, regardless of whether they’re hidden or not
(You need to quit SKYPE first):
Use any editor like Word Pad or Word, as shared.xml is a real text file. For Windows XP, you can just double click, amend and save. But you MUST EXIT SKYPE
You should check your Shared.xml
In <VoiceEng> You need to insert <AGC>0</AGC> (see below)
<VoiceEng>
<AGC>0</AGC> <------ADD this line and set to zero
MicVolume>100</MicVolume>
</VoiceEng>
Note:
For Vers 2.5:
255 is max volume and 0 = low. Range is 0 (off) to 255 (maxim)
255 could be much too high, so please reduce if necessary
For Vers 2.6
100 is maxim volume and 0 = low. Range is 0 (off) to 100 maxim.
If the volume is too high, the sound will be distorted and clipped
Set for best audio quality, use echo123.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jun 17, 2009 | Computers & Internet
V6105NR MICROPHONES DO NOT TRANSMIT
Does your microphone work with other applications.  If you are running windows XP, go to Start>all programs>accessories>entertainment>sound recorder.  Record your self and play it back.  If you can hear yourself, then the issue is with skype.  Make sure you go through the audio setup wizard in skype to get the best preformace out of your microphone.  If no other programs work, then you may need to reinstall the drivers for that microphone and try it again.
Mar 04, 2009 | HP Compaq Presario V6105NR Notebook
Cannot hear my voice in the skype test skype is set up on the ubuntu operating system
Firstly, what version of Ubuntu and Skype are you using? Also what machine.
There are three areas where the issue could be - within Skype's settings, withing Ubuntu's settings or with the microphone/soundcard.
I'll cover some quick attempts at solving, assuming it's the first two.
OK, first make sure Ubuntu's settings are correct. If you can access the sound settings (generally there is a Speaker icon in the top right). Right click, 'open volume control'. Often you need the 'boost' level as well as the usual microphone - if you have 'Front Mic', sometimes you need 'Front Mic Boost too', likewise if you have 'Microphone', you might need 'Microphone Boost'. In the Volume Control, click preference to add the 'boost' level.
If that didn't work it might be your Skype settings. In Skype options, 'sound devices' try changing the 'sound in'.
If those didn't work it might be hardware (or another trickier software issue) - try testing your microphone on something else.
Feb 27, 2009 | HP Compaq nx9030 Notebook
How to install microphone in laptop?
when the times we chat in yahoomessenger,my auntie call me she did not hear any sound from my laptop,,so haow to install microphone?
Jan 02, 2009 | HP Compaq Presario CQ50-210US Notebook
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Logitech quick cam communicate stx on Vista - microphone not working
Why isn't the microphone on my camera working?
trnsp.gif Answer The microphone may not work because of a hardware or configuration problem. To determine if it's a hardware problem, test the microphone in Sound Recorder.
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
The microphone may also be defective. To test this, try the camera on another USB enabled system.
If you can record sound in Sound Recorder, but not in the QuickCam application, try setting the Logitech Microphone as the Preferred device in Audio Properties.
This article covers how to configure a Logitech camera's audio and video settings to work with Skype 3.6 or above. trnsp.gif Answer This article applies to the following cameras:
QuickCam Orbit AF
QuickCam Pro for Notebooks
QuickCam Pro 9000
This article applies to the following platforms:
Windows Vista
Windows XP
This article applies to the following 3rd party application:
Skype™ 3.6 or above
To set up Skype for video please be sure that your Logitech webcam is connected and working. This can be verifed by launching your QuickCam software and checking for a video stream withinin the QuickCapture video window. Once the webcam functionality is verified, please close the QuickCam application and follow the steps below.
  1. Launch Skype™ and click on "Tools" as shown in the figure below
    Fig 1
  2. When you click on "Tools" you will see a drop down list
    Fig 2
  3. Click on "Options" at the bottom of the drop-down list
    Fig 3
  4. A new screen appears. Click on the left side of the pane under "Video Settings"
    Fig 4
  5. Under the "Select webcam" drop down, please choose your Logitech camera, then click the "Save" button.
    Fig 5
  6. Click on "Tools" as shown in Fig 6 to get your Logitech Audio setup.
    Fig 6
  7. When you click on "Tools" you will see a drop down list
    Fig 7
  8. At the very bottom of the drop down list, please click on "Options"
    Fig 8
  9. When you click on "Options" you will see a new screen
    Fig 9
  10. On this new screen click on the left side of the pane under "Audio Settings"
    Fig 10
  11. You will now have the option to select your Logitech camera's Microphone as your main Audio source. Under the "Microphone" drop down, select the Logitech Microphone, and click "Save"
    Fig 11
  12. You should now be ready to use your Logitech webcam and microphone in a Skype video call.
Mar 25, 2008 | Logitech QuickCam Communicate STX Personal...
Dell Dimension 3100 PC Desktop Logo
532 people viewed this question
Alun Cox
