Question about GE JVM1440 Microwave Oven
My turntable stopped rotating on my GEJVM1490 for no reason. everything else works fine, any suggestions?
  • 109 Answers
There is a small motor underneath the microwave which turns the plate or turntable around.
If this is faulty then you will need a service agent to repair it.
Posted on Jun 17, 2009
Glass plate does not rotate
Here are a couple videos that show you how to replace the turntable motor and diagnose
Feb 10, 2015 | Panasonic Microwave Ovens
Microwave turn table quit rotating
With the model number, we may have been able to give you a link to the actual service manual. Without it, we can only give you general answers.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes, then try it again.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
The turntable pad is used to turn it off for cooking without the turntable, then to turn it back on when you do want to use the turntable.You can find links to helpful exploded view diagrams and part ordering help here.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
Aug 10, 2013 | Microwave Ovens
Turntable stopped rotating. Everything else works fine.
It sounds like the turntable motor has failed. It is a synchronus motor with a plastic gearbox reducing the RPM to about 5. The gears fail when the turntable dish is turned as the motor stalls the shafts.
Replacing the motor is no big deal.
There is usually an inspection cover that can be removed on the underside of the cavity.
Remove the cover and remove the motor.
Replace with the same type and the reverse procedure will fix it.
You may however require a self tapping screw to affix the cover back on. A bit of a puzzle but not too difficult to work out!
Hope this helps.
Nov 29, 2010 | Whirlpool MT4155SP Microwave Oven
I hv a 24ltr Sharp Carasoul Microwave. Few days back, its plate stopped working, but its heating the food fine. Why has the plate stopped rotating? Will the food be evenly heated even though the plate...
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
You order Sharp parts Encompass here or call them toll-free at 866-779-5835.
> Will the food be evenly heated even though the plate is not rotating?
No.
Sep 07, 2010 | Sharp R-1480 Microwave Oven
The turntable on my Russell Hobbs SJS21 Microwave has stopped revolving?
I would contact the manufacturer via info in your owner's manual.
If for some reason you don't have your owner's manual, I would suggest calling the dealer where you bought it to see if they have a number for them.
Feb 09, 2010 | Microwave Ovens
Microwave turntable doesn't turn. Everything else
But if you've recently had trouble with the cooktop lights, then the control board may be damaged.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Nov 28, 2009 | Frigidaire Microwave Ovens
I have Emerson mcirowave model AT1120. Everything works fine except the turntable does not rotate. How can I fix this? thanks.
Not an Emerson answer, but a reasonable guess based on what I found working on other names:
Three reasons it will not rotate, 1) the motor does not get the command to rotate, 2) the motor gets the command but it is dead, 3) the little driver doojig is broken. This part locks to the motor with several interlacing fingers - pull it up to remove.
In my experience, you can replace the motor and you can replace the doojig that the motor turns to spin the plate.
I hope this helps you solve your problem.
Thanks
Oct 18, 2009 | Microwave Ovens
Turntable does not rotate
Well it seems that there is some fault in the turnable motor, turntable system consists of the motor and coupler, turntable support with rollers and the tray.
I have a video link to help you more on this -- how a turntable motor should sound when you rotate it by hand... please follow the below link -
http://www.youtube.com/watch?v=rPSWi_z7M58
If motor grinding... etc., it means you may have a bad motor or plastic coupler.
Post further comments if you need more help....
Good Luck!!
Mar 14, 2009 | Microwave Ovens
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1440 Microwave Oven Logo
174 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
