Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
Problem for Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
V-chip code forgotten
By tgord on Nov 01, 2007
I have a Toshiba mv20p2 and have forgotten the v-chip code.  How do I reset or change it?
Same Problem
Jun 10, 2008
-   i just aquired a toshiba tv with the dvd and cd. i need the code to unlock the v chip.
PLEASE HELP.
JANICE P.
-   matt050201
Feb 09, 2008
-   I NEED MY V CHIP CODE
-   Guest
Jan 19, 2008
-   We ave a rental unit with a Toshiba TV and one of our renters must have set the V-chip and I have no idea what the PIN is.
Please help!!!!!
Len-   lifeisfun
Dec 04, 2007
-   Yes, we also have a toshiba tv which is only occassionally used and we forgot the vchip code
help?
karla-   kmswalsh
Nov 25, 2007
-   I have a 52 inch RCA and the password is lost so I cannot remove it. Please help.-   Guest
Best Solution
posted on Sep 16, 2008
Very Helpful)
dokc36
Rank: Apprentice
Rating: 100%, 1 votes
v-chop code forgotten and remote for t.v. old and not working corectlyl how do I reset or change this?
Was this helpful?
Yes
No
Solution #2
posted on Aug 16, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thank you, that worked!
Solution #3
posted on Aug 14, 2008
Very Helpful)
jjjj9005
Rank: Apprentice
I had this problem with an older Toshiba TV/VCR combo (2001), Model 3 MV13L3. I contacted Toshiba for help with this and this worked (yeah!!!)
Changing V-Chip Settings for MV13L3, TV/VCR Combo 2001. This should work with Toshiba V-Chip settings for other models also.
-Unplug your tv for 1 minute.
-Plug your tv in and turn it on.
-hold the volume down button on the tv at the same time you hold the "0" button down on the remote. This will bring up the "Set V-Chip" blue screen.
-Enter "0000" for the password and hit enter. Enter "0000" to confirm the password and hit enter.
-This will bring up the V-Chip set page. From this page you can: Turn Off the V-Chip, Change the Limits for viewing, etc.
-If you turn off the V-Chip setting, you will not have to deal with this problem again.
Was this helpful?
Yes
No
Solution #4
posted on May 11, 2009
Not Rated)
pennywisezzz
Rank: Guide
Rating: 0%, 0 votes
I found this to work on my Toshiba TV/VHS combo MV19M4 after trying others suggestions that had worked on similar models but nothing worked on mine. Maybe it will work for yours. Follow these steps:
1: Unplug the TV for 1 minute then plug it back in.
2: In the menu select "TV Set Up".
3: Move the blinking block to beside "V-CHIP Set" BUT DO NOT SELECT IT.
4: Hold in the number 1 button on the remote.
5: Hold in the volume down button on the TV.
Your TV will turn off. Give it a few seconds to reset itself and then turn it back on and you will have to completely reprogram your settings. When you go to the V-CHIP settings it will ask for your new code.
- Jenny
Was this helpful?
Yes
No
Solution #5
posted on Jul 20, 2008
Not Rated)
tkhua91
Rank: Apprentice
Rating: 0%, 0 votes
i have the same problem with my Tv, try to do this: Turn the TV power off, click MUTE , press 8-2-4, and power on. It should reset back to 0-0-0-0.Goodluck
Was this helpful?
Yes
No
Popular Solutions for Toshiba MW20FP1 20 in.
Questions and Unsolved Problems for Toshiba MW20FP1 20 in.
Do you recommend Toshiba MW20FP1 20 in. TV/VCR/DVD Combo?
Answer
Answer
I mostly use my dvd player to watch movies, but I do own or watch VHS tapes from time to time. I own... (More)
Answer
I got an old phillips box tv from work but some jagoff had the parental code installed. The guy that... (More)
Answer
Toshiba Mw20FP1 hums when tv is turned off. is that normal?
Answer
Screen shows the date and an code of 573b you can not watch the tv. how do I get this off or... (More)
Answer
Both the remote and the button will not turn the TV off. Once off, the remote and button will turn... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba MW20FP1 20 in....:
Top TV Combo Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more TV Combo Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
