Cars & Trucks Logo
Per Krs Posted on Apr 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Abs lamp is on. I cant get tuareg in gear
Cant get car in gear
TCI
Level 3:
Master:
  • Volkswagen Master 733 Answers
  • Posted on Apr 08, 2014
TCI
Volkswagen Master
Level 3:
Master:
Answers
733
Questions
0
Helped
226566
Points
1542
2 DIFFERENT PROBLEMS ONE MUST HAVE COME FIRST.ANYWAY CHECK FUSES AND IF NO BURNT ONES TOW THE CAR TO UR NEAREST VW DEALER!!
1helpful
My hummer h3 keys wont turn ignition i bought a new battery .Still wont turn im thinking its a fuse but all look good ._i cant let my windows up
What year is it ? Turning the key on , nothing works ? Do the head lamps work ? are they bright ? Instrument cluster warning lamps come on with key on - check engine , air bag , ABS , etc....
2answers
1995 Isuzu Rodeo back lights not working. Fuse and bulbs are all good. Changed out the ABS controller and checked all wiring.
The ABS controller has nothing to do with the back lights. Please anyone reading this post, do not mess with anything concerning ABS systems. An ABS light on will not effect conventional brake function. It can only be serviced by a trained tech. Also very expensive. Your original problem is most likely at the harness connector, located in the frame between the rear axel and bumper. If the truck has been used for pulling and launching a boat, this is where a trailer light harness is tapped into for trailer lights. Backing a boat into the water compromises this connector. (corrosion will not let the truck lights work) The connector is usually on left side frame rail) Conductive grease after cleaning
My abs light on and flashing and i cant put it in any gear just park
Year/make/model?? There may be an override button to depress to get vehicle in gear from a lock position. You will need to have the ABS codes scanned to determine the source of the problem. You can also try disconnecting / reconnecting the battery to see if it will reset the ABS system and allow the gearshift to move
Dash board indicate aps flashing
aps ( you ment ABS?) do tell.
What stops, car, engine, what?
one of these lamps?
http://dashboardsymbols.com/the-symbols/
lost your operators guide. for correct name>
it tells you what to do for each warning , why not read that.
id guess, it says take it in for service. id bet.
3 engines and 2 transmissions.
1.3 L L13A i-DSI SOHC I4
1.5 L L15A2 i-DSI SOHC I4
1.5 L L15A1 VTEC SOHC I4
no City cars here, USA< so cant find your manual for free
try Honda dealer for a real manual , get one and avoid,
costly repairs, and being standard.
igoring lamps can be costly or unsafe, eg: ABS. is one that is never
to be ignored, (brakes)
The mecanic say that the abs model is not working n he say that the model is next too the brake bump cant some one tell me how that look lik
If you take wheel off you will see wire going to back of brake with round gear with Teeth on it that's the sensor
Abs light flashing;no brake lights; no radio no flashers and cant take out of gear
Based on the list of problems, my guess would be the key switch or a fuse problem. You are dealing with 4 different problems since the brake light switch and the shifter could be related.
I would check for ABS codes first.
Abs light is on trany strock on secound gear
If the second gear problem happened just as the ABS lamp came on.....Car is in Limp Mode.
ABS system has set likely a code about safety...ie" Brake system failure..... although 3rd gear is usual default.
You must scan for codes and remedy the fault/s.
I changed my suspension to coil spring now my abs light is on and cant turn on trac tion controll. i left height adjusters hooked up but disconnected air solinoid then tried hooking up air solinoid...
Retrieve the codes you have ,that set the Malfunction Indicator
Lamp for the ABS
Diagnose from the code
May be a bad Wheel Speed Sensor ,nothing related
to what you changed
You will see the wiring going to each speed sensor behind
each of your 4 wheel hubs
1helpful
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
