Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
Got a point type 5hp briggs model 130292. I want to do away with the points. help
    Problem Solver:
  • 13 Answers
Something is causing the spark timing to be late. Check it with an old neon timing light after marking top-dead-center with paint. .
Posted on Sep 18, 2009
  • Thomas Merrill
    Thomas Merrill Sep 18, 2009
    Change the coil to a pointless type or add a chip to the old coil, cut the wires to the pointsl. No need to remove the flywheel just the sheet metal housing..Connect the kill switch wire to the coil.
  • 32 Answers
You can but its a lot of work just clean the points and reset and go
Posted on Jul 20, 2009
I have a Briggs & Stratton tiller motor 5hp that does not have points.there are two wires terminated to the coil.1 with a ring terminal and 1 with a stripped end.Where do they go?
the wire with the ring terminal will go under a mounting bolt ( ground) the other will connect to the plate at the end of the throttle cable under the insulated bit
when you push the throttle to stop , that plate will short out the wire with the stripped end and top the engine
Jan 07, 2017 | Briggs & Stratton Garden
Briggs and Stratton 5hp starter shaft doesn't engage
use the free sign and encourage people to take it
Apr 12, 2017 | Atlas Translator Garden
Repair manual for briggs & stratton 5hp model # 130202 type 0200-02
http://www.jackssmallengines.com/Jacks-Parts-Lookup/Manufacturer/briggs-stratton/70798 Try this link it should help. You can click on B&S and enter your model and choose diagram you like.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 09, 2012 | Briggs & Stratton Garden
Oo.comI need a motor diagram for Briggs and Stratton 5HP shredder chipper
Get the model and type number off the engine and you can go to a website like partstree.com or others and with the brand and the model and type number you can get diagrams of the engine.
I hope this is helpful for you.
Aug 13, 2011 | Troy-Bilt® Briggs and Stratton Chipper
This is a Briggs and Stratton Rototiller, Model 130292-1636-02. I think my Armature might be bad. This is a Briggs and Stratton part # 397358 with electronic trigger (starter). After cleaning my fly-wheel...
the fly wheel is touche you need no more than 5 thousands clearance between the
fly wheel and the coil for the best spark
now on the other hand if you have points on this unit its best to put in new points
and condenser and set the points the same settings as the coil
this will get spark for you
hope this helps you
good luck
bob
May 08, 2011 | Ford Mustang Cars & Trucks
Need the magneto gap on an old 5hp briggs
The gap on the points is to be set at 0.20 and the coil is set 0.10.
Hope tis is what you needed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 11, 2010 | Briggs & Stratton Garden
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Same problem - Slow engine speed doesn't run smooth either
You should look at the numbers AFTER the model and type number you noted in your post. The first two digits of the CODE are the year the engine was made. This looks to me like an old 5hp Briggs....old enough that it wouldn't have electronic ignition. If it has the old points and condenser, it could likely need a tune up. Electronic ignition modules or electronic ignition coils are available for this engine - see your Briggs dealer.
If you had the gas tank off, did you replace the gasket between the carb and engine block? This particular engine uses 2 (two) gaskets, not one.
By the way, you don't want to make a governor spring. It's best to use the one specifically manufactured for this particular engine or you run the risk of over-revving.
Jun 07, 2009 | Troy-Bilt Pony Garden Tiller
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
1,268 people viewed this question
Top Briggs & Stratton Hammering Experts
rlev_7
Level 1 Expert
JOHN LAPIER
Matt Olenzek
Matt Olenzek
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
