Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Help, how do I use this cleaner?
My sister also let me borrow her cleaner and I cannot figure out how to keep the brush on the floor and tilt the handle.Any help would be greatly appreciated, especially since I have been using the squirt handle and now have a wet cqarpet that I can't seem to get the water up.
  • 25 Answers
Hit the lever on the right side that will lower the handle and clean tank
Posted on Jun 21, 2009
Is there a more efficient way to clean the brush assembly on the max extract dual v other than running the assembly under water? The bristles are loaded with carpet fuzz and remains of doggy doo
Following is the procedure for removing the brushes.
  • Your cleaner is equipped with removable brushes. Follow these directions for changing brush assemblies or for easy cleaning. How to Remove To prevent possible leaking, remove Clean Water Tank and Dirty Water Tank. Set tanks aside. With handle in upright position, tilt cleaner back until handle rests on the floor. 5.3 Grab brush assembly and pull firmly.
  • The brushes can be cleaned under running water. ! CAUTION ! To reduce the risk of injury from moving parts, unplug cleaner before servicing.
See page 17 of the link manual for the details
http://hoover.com/file/594
Dec 10, 2015 | Vacuums
Motor runs but brush don't spin and belt is not broken
Two core baseline things to check. Brush won't spin if the handle is all the way forward (this is where the handle mode engages), so tilt it back before turning unit over to check the brush. Also, run the brush clutch back and forth between hard floor and carpet mode a couple of times and make sure the clutch is fully engaged. Hoping it might be as straigtforward as that (I just picked up a Dyson at a flea market, a really good deal since I couldn't get the brush to spin there. After some research at home, the above finally entered my sphere of knowledge, and no problems with the brush since (other than cutting large volumes of Labrador hair off of it).
Aug 27, 2015 | Dyson DC28 Animal Airmuscle Vacuum Cleaner
Why does the brush continue to rotate on bare floor setting as well as using hose attachments?
Hello! The brush roll shut-off feature is on select models. Your vacuum may or may not have this feature. If it does not, the brushes will continue to rotate while hose is removed or in use and at all times while cleaner is on. The vacuum must be in the upright position to lift rotation brush off the carpet when cleaning above the floor. Be sure the vacuum does not tilt forward when doing above floor cleaning. Hope this was helpful!
Aug 10, 2014 | Dirt Devil Vacuums
How do you change the scrub heads on a Floormate SpinScrub 500?
Hey there! To change out your brush heads simply follow the instructions below.
1. Remove the nozzle by pulling the two nozzle release buttons.
2. Tilt cleaner back so handle rests on floor.
3. Push two brush release buttons and remove the brush assembly.
4. To replace brushes align post on brush block with hole on bottom of cleaner. Turn brushes slightly until post fits easily into hole. Press brush assembly firmly to snap into place.
Hope this helps!
Jul 05, 2014 | Hoover H3030 FloorMate SpinScrub 500...
How do i disassemble my hoover f7220
Hi there! The tanks, brushes, nozzle and handle can be removed from the cleaner by following these quick steps below.
1. To remove the clean water tank simply grasp the handle and push down on handle to unlock it, then pull the tank out by the handle.
2. To remove the dirty water tank, slide the latches open located on the sides of the cleaner that hold the tank to the base of the cleaner. Grasp the handle and pull up and off.
3. For brush removal, with the handle in the upright position, tilt cleaner back until handle rests on floor. Grab brush assembly and pull firmly.
4. To remove the nozzle, with handle in upright position, tilt cleaner back until handle rests on floor. Pull tab at rear edge of nozzle and pull forward to remove nozzle.
5. For handle removal simply remove the handle screw and lift up on handle.
Disassembly beyond this point is not recommended. Hope this helps!
Jun 05, 2014 | Hoover F7425-900 SteamVac V2 Widepath...
I've borrowed my sister's Dyson(she's away on vacation) to see how hell it works. The problem I'm having is that I can't find the release button to tilt the powerhead back towards me,...
The DC07 is engineered to recline into the vacuuming position without a release button - just place one foot on the cleaner head, and tilt the handle back.
For more advice on using the cleaner, you might want to refer to the user guide. If you don't have this to hand, you can download a copy here:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
If you have any further questions about using or maintaining the Dyson which aren't covered by the user guide, please get in touch with us directly. One of our experts will be happy to provide the assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Aug 24, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My vacuum cleaner belt keeps burning up as soon as
CHECK ROLLER BRUSH PROBALLY HAS STRING WRAP UP AROUND THE ROLLER OR THE END BEARINGS ARE FROZEN IF SO SRAY WD40 IN BEARINGS TILL THEY FREE UP OR REPLACE ROLLER BRUSH
Nov 03, 2009 | Bissell 6594 PowerForce Bagless Upright...
Hover F7452-900
Regarding the brushes not turning:
Your filter may need to be cleaned. It is located behind your brushes. With your tanks removed and the cleaner unplugged; tilt your cleaner back. The filter screen located behind your brushes can be removed by squeezing the sides of the filter and lifting and pulling toward you. Clean and replace.
It would be difficult for me to advise you any further without seeing exactly what you have done.
Aug 09, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Nov 26, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
