Rs2544sl water wont work
You push the water dispenser lever in and it applies power to an electric valve (solenoid) which opens and allows the water to flow.
So, there are two components to look at: 1. the electrical switch attached to the lever; 2. the solenoid valve.
Secondary things to check: Is the water connected? Is the shutoff valve on the wall open? Is the tubing clogged with mineral deposits? Are any wires for the water dispenser switch or solenoid disconnected, chewed through by that dead (electrocuted) mouse under the refrigerator?
Hope this helps...
Good Luck!
