I'm having a problem assembling my Samsung 2033 sw monitor. The directions are horrible and I don't want to snap the base.
    Problem Solver:
I bought a Samsung 2033sw Monitor and I couldn't get the base attached to the monitor. When I returned it to Best Buy their "geek"
technicians discovered after opening another new monitor that
the spindle was attached to the monitor at the factory. But on
the monitor that I had problem with, the spindle was simply
put in the box along with the base plate. Best Buy solved the problem by disassembling the monitor itself and then installed the complete base assembly. You should return your monitor and asked the sales associate or manager to let you see another new monitor. The only thing you need to attached to the monitor is the round base plate.
Posted on Sep 17, 2009
Don't have the directions to put evenflo exersaucer together, need help. Is there somewhere I can get the directions? reg. number 07T-0538604
Instructions
    • 1 Place the large, round base on the floor. The outwardly curving edge should be facing downward.
    • 2 Attach the three pedestals to the base. To do so, insert your finger into each pedestal and loop the spring within around the hook found on the base in the appropriate holes. Insert the three plastic tabs on each pedestal into the base, locking them into place.
    • 3 Press the wider end of a lower leg assembly onto each pedestal piece. By wiggling the lower leg assembly side to side, you will eventually snap the pieces into place.
    • 4 Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
    • 5 Insert the cloth seat into the seat ring, aligning the diamond on the cloth seat with the triangle on the seat ring. Each plastic tab lining the edge of the cloth seat attaches to a peg on the seat ring. Snap these connections into place.
    • 6 Hold the Exersaucer tray on its side and press the seat ring into the center. Once the seat ring snaps into place, it should be able to spin in place.
    • 7 Attach the three spring caps to the Exersaucer tray. These spring caps cover the three large holes in your tray, and are attached by a firm clockwise twist.
    • 8 Attach the upper leg assemblies to the upper leg crowns. These crowns act as the "socket" and the upper leg assemblies act as the "ball." By pressing them together with a click, the upper leg assemblies can twist and rotate in place.
    • 9 Turn the tray upside down and press each upper leg crown base into the round holes in the tray with a firm twist. Each upper leg crown features a height adjustment hole, which will face outward when properly attached.
    • 10 Turn over the tray so that the upper leg assemblies are facing downward. Insert each upper leg assembly into a lower leg assembly, being sure to pull away the height adjustment tab to allow the assemblies to slide together.
    • 11 Press each toy into its respective port on the surface of the tray. The toys each have a distinct base, which clicks into the correspondingly shaped tray port
May 10, 2011 | Toys
My monitor still works great and I love it. However, in trying to move the tilt adjustment, the pop-metal tabs that slip into the back of the monitor screen snapped right off. Is there a way to purchase...
I'm pretty sure that these monitors are built/assembled overseas and it would not be worth trying to get buy a new base (if it was available). Your best bet is to have someone build you a new frame to support the monitor in.
Regards,
Yavacotech
Jan 16, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
I bought my samsung 2033 a month ago. It recently has started to turn itself on and off. Also occasionally no effect when trying change channels.
I have to send mine back to Samsung because of the same problem. Samsung is now like Toyota not disclosing know problems.
May 20, 2010 | Samsung Syncmaster 2033SW Monitor
Syncmaster 2033SW Monitor: I bought my samsung 2033 a month ago. It recently ...
I would take it back right away, when electronics break down in lees than 6 months it is not a good sign. Get the replacement or have it fixed under warranty.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 18, 2010 | Samsung Syncmaster 2033SW Monitor
I have a Samsung Monotor that I cannot get to work
common prolem. power supplies go bad. ws it new? if so return it. if it was preowned ship it to us and we can fix it. usally $50 plus return shipping. auburntechnology.com
Dec 30, 2009 | Computers & Internet
I am having problem assembling samsung lcd monitor 2033.the moniter and the base doesn't join...
Keep the stand on floor as such the arrow is pointing towards you....
Place your palm in the lower rear side of the monitor.
Align the monitor upon the stand and press the monitor firmly, using your palm... You should press somewhat firmly to fix it... All the Best...
Sep 05, 2009 | Computers & Internet
Attaching Samsung 2033 monitor to base
The solution is that you simply have to really force the monitor onto the base post. Thanks anyhow.
Jun 23, 2009 | Samsung 204T 20" LCD Monitor
Computers & Internet Logo
914 people viewed this question
Alun Cox
David Payne
David Payne
