Question about ORIS TT1 Divers Titanium Chronograph Watch 67475427054RS
I need extra watch band links for my Oris titanium divers watch. Any help in finding these.
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
The schlatter.org solution is for the other type of casio band I've run into.
The wristband with the arrows has a fine pictorial solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band
Basically you use a very very fine poker to poke the pins out in the direction of the arrows.
NOTE: you can't poke them out if you will drive them into your work surface, so think about that before you start.
Posted on Feb 02, 2008
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
  • 4 Answers
SOURCE: Remove link from Watch Band
I would suggest that you take it to local jewler or watch repair center, it normally runs less then $10 to remove an unlimited number.
Wal-Mart used to be a good place to go, but have since decided to support only watches that are sold in the store, which are crappy at best.
If you want to do it personally...I would discouage it. It is normally a simple process but without training, can turn into a big problem with minimal effort.
Have a great day!
Posted on Jan 13, 2009
escapement
  • 2334 Answers
SOURCE: How do I get the pins out of the titanium band for Casio PAW1500T
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jul 09, 2009
SOURCE: Need extra link for an Anne Klein 10-7977MPTT watch
I called Anne Klein saying I wanted to purchase additional links for an Anne Klein watch I had purchased, and I was (very kindly) instructed to call the following number between 8am and 5pm EST: 1-800-937-0050 ext. 203. I'll be calling tomorrow. Good luck!
Posted on Nov 04, 2009
How do you take a link out of a skagen titanium 105ltx
How to Adjust a Skagen Watchband ' Our Everyday Life
https://oureverydaylife.com > Style
Skagen watches are not difficult to adjust, and come in two forms--the mesh ... Use the driving tool (a thumbtack will work) to push the pin out of one of the links. ... If you're uncomfortable with adjusting your band, take it to your local jeweler. Missing: titanium ‎105ltx
FAQ - Skagen
https://www.skagen.com/en-us/faq Titanium · Chronograph · Solar · Interchangeable Watches · Watch Straps ..... A: Extra links for link bands can be ordered by calling our Customer Care ... Visit Warranty & Repairs for more information about how to get your watch crystal repaired. ... Q: Why don't you send out watch parts when I need them to repair my watch?Missing: 105ltx ‎' ‎Must include: ‎105ltx
Jul 29, 2018 | Skagen Watches
How do I get extra links for the band.
You can find a place that sells them online for example
Or even go down to your local watch seller/engraver/fixer and ask if the sell them
Oct 01, 2014 | Watches
Ive had my Seiko automatic titanium scuba 200m about 3 years when i got it, i had it sized down by taking out 3 links which the store gave me back and 3 pins that go with , ive put on a few pounds maxed...
Thanks for contacting FixYa.
Seiko normally will send out up to 5 extra links on new watches. I am not sure on watches that are 3 years old but you will need to contact Seiko on this one. MAYBE a watchmaker locally will have some extra peices that will work too.
You can contact Seiko here:
http://www.seikousa.com/support/customer/northamerica.html
Best regards.
Jewel
Aug 30, 2010 | Seiko Diver's Watch
Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    Main spring repair
    A professional watchmaker can replace the mainspring and clean and lubricate your watch for you.
    Hope this helps,
    Ken
    Yellowstone Watch, Inc.
    www.yellowstonewatch.com
    May 20, 2010 | ORIS TT1 Diver Date Steel 44mm Bracelet...
    TTI DIVER BEZAL
    GOTO
    http://www.watch-clock-makers.org/
    Hope this tip helps.
    r/ David
    http://antiqueclock.clockstop.com/
    Mar 09, 2010 | ORIS TT1 Divers Der Meistertaucher...
    Adjust Watch Band
    Click on my profile, then click on TIPS AND TRICKS. There you will find explanation how to add or remove links. Rate me, plz.
    Feb 24, 2010 | Timex Ironman Triathlon Hi Ti Watch,...
    I have an invicta pro diver watch with stainless steel band. I need to buy 2 or 3 links and pins. Would a new band be better and where do I buy either item? Ilive in area code 75601, Longview, Texas. Thank...
    I know of a couple places in San Antonio and Austin that would be able to custom fit your new band or help you with a repair.
    Precision Time
    They are located in the malls in either city. They also have a web site.
    PrecisionTimeCo.com
    You can try to contact Invicta for new links and they may have them depending on the age of the model. Look at your owners manual for contact information.
    Sep 18, 2009 | Invicta Automatic Pro Diver 8926 Watch
    ORIS TT1 Divers Titanium Chronograph Watch 67475427054RS Logo
    215 people viewed this question
    Top ORIS Watches Experts
    Ansel Alberto
    Ansel Alberto
    Marvin
    Marvin
    Are you an ORIS Watch Expert? Answer questions, earn points and help others
