Microphone used with skype program stopped working after technition fixed email issues. He has no idea why
    Brigadier General:
  • 8,619 Answers
Hi
Try changing your sound mode in skype from ALSA to OSS (I know OSS isn't great but skype likes it more, ALSA support is still new). Then close any other application that could possibly be using sound, and restart skype.
The major problem with OSS is that it allows only one program to access the sound at any time, which is probaby why your audacity isn't detecting the input either - there could be a setting somewhere set to oss. SO just try closing everything like I've said above.
If it still does not work then First go to tools-->options-->sound Devices-->(UN) tick, Let Skype Adjust My Sound Settings.-->save
Reboot/Restart SKYPE i.e Log Out and Back in USING your password.
With AGC disabled you can monitor AND ADJUST the microphone level DURING A VOICE CALL using windows recording sound properties. Just drag the slider up or down for best volume without clipping. When the call ends the NEW setting that you just made manually is written back to shared.xml and will be used for the next call.
Attention: MS sound recorder will NOT do this job
Save
Retest and see if its OK.
If not do below:
Enter:
%AppData%\Skype\ in the address bar of Windows Explorer and it will display all files, regardless of whether they’re hidden or not
(You need to quit SKYPE first):
Use any editor like Word Pad or Word, as shared.xml is a real text file. For Windows XP, you can just double click, amend and save. But you MUST EXIT SKYPE
You should check your Shared.xml
In <VoiceEng> You need to insert <AGC>0</AGC> (see below)
<VoiceEng>
<AGC>0</AGC> <------ADD this line and set to zero
MicVolume>100</MicVolume>
</VoiceEng>
Note:
For Vers 2.5:
255 is max volume and 0 = low. Range is 0 (off) to 255 (maxim)
255 could be much too high, so please reduce if necessary
For Vers 2.6
100 is maxim volume and 0 = low. Range is 0 (off) to 100 maxim.
If the volume is too high, the sound will be distorted and clipped
Set for best audio quality, use echo123.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 17, 2009
Microphone doesnt work with skype
I've heard of this problem alot, I took 10 minutes today with my friend with this headset to figure out a fix.
From what i can tell, Skype doesnt pick up the Microphones input.
The only solution I could figure out so far has been this.
A voice changing program called MorphVox Pro (by Screaming bee) offers a Trial.
If you download it, and set up your microphone on this to work, You can then in skype select the MorphVOX Pro as your microphone, and you can use this chat program to work with your headset.
This is only a temporary fix But it is a step in the right direction, I'll be forwarding my email to Razer later to try and get some updates for the headset.
Best Regards
Ricky.
Feb 09, 2013 | Razer Chimaera 5.1 Wireless Gaming Headset...
Tip
Stop Skype from Crashing in Windows 8
it's detected in the different operating systems that it crashes while contacting with others via instant messages, webcams or microphones. In such circumstances, you have no need to get depressed, contacting Skype Customer service professionals you can eradicate this problem easily and efficiently. Here are some ways you can also follow up to solve the Skype crashing problems.
Fix #1: Repair Skype Installation
Sometimes, an inaccurate installation of the program can cause Skype to crash. So, follow up the procedure mentioned below to fix the Skype installation issues:
    1.Go to the 'Start' menu and then click the 'Search' box.
    2.Next, input the 'Control Panel' in the box, and click the 'Apps' icon.
    3.From the Results, Choose the 'Control Panel,' and then click the 'More Settings' button.
    4.Click on the 'Programs' icon and go to the 'Programs and Features.'
    5.Locate the Skype program and right-click on it. Choose the 'Uninstall' option.
    6.Click the 'Repair Option.' It will repair the installation file automatically. Fix #2: Re-enable the Skype Add-on in the Browser
    While installing the Skype program, its add-on is automatically installed in the web browser. Sometimes, issues with the plug-ins often cause Skype to freeze and crash. Here's how to re-enable the plug-in.
      1.Open your web browser and click the 'Menu' option.
      2.Choose the 'Tools' option, followed by the 'Extensions.'
      3.Locate the Skype icon, and deselect the 'Enabled' checkbox.
      4.Re-open your browser program. Again, repeat the same process and go to the Check box for Skype.
      5.Next, select the 'Enabled' checkbox. Fix #3: Update Audio/Video Drivers
      Sometimes, out-of-date graphic drivers can encounter various issues with Skype. So, update the audio and video drivers of your system with the latest version that you can download from the manufacturer's site. Here, you will find the updated version, choose the compatible one and follow up the instructions to install them. At such time, you can seek the help of either Skype technicians or Microsoft support professionals.
      Fix #4: Optimize Registry
      Whenever you reinstall and uninstall a program, Windows registry is up-to-date about it. Although, a registry is interrupted when irregular activities are outdone in the operating system. So, download and install a registry cleaner for Windows 8 that will let you clear out several registry issues on your PC. It will clean the registry of your program automatically.
      Fix #5: Install Latest Direct X
      If your Skype program is running slowly or often crashing or freezing, then download and install the new version of the Microsoft Direct X to fix the issue and boost up the Skype performance effectively.
      Fix #6: Check your Antivirus Software
      It's possible that the virus can attack your PC from any open source. Additionally, it critically influences the system performance and slows it down. At such time, your Skype program also gets infected by it. So, install trustworthy security software to scan your computer and detect/remove the threatening programs. Also, ensure that your security program isn't blocking the Skype from working. If it's, then seek the help for it to detect the cause and fix the issue instantly.
on Jan 10, 2017 | Miscellaneous
Using medion md 96340 with built-in realtek hd audio sound card. in skype video calls the caller can hear very well but called person does not hear at all. skype echo test says-cannot find sound...
Analysis- The call can gear very well - indicates that the speakers / head phones are working fine and the audio drivers are working well
The called person doesnt hear any thing - it indicates that the caller is not able to transmit sound. This can be a microphone related issue. It can also be skype settings issue.
Please answer following questions to analyze the issue better
1. has this ever worked before?
2. Have you tried using the microphone for some other application like recording some audio?
3. Have you tried audio / video calls using some other chat program like gtalk?
4. Are u using any external microphone attached to a head set or is it the laptops inbuilt microphone?
-IAmAraldite
Aug 18, 2011 | Medion MD 96340 Laptop
Can you pls let me know how do I fix my laptop microphone (HP Pavillion dv1000); when using skype others cannot hear me (or when I do the test on skype, I cannot hear my own message). I have checked the...
Assuming you are using Windows 7
<Start>, <Cotrol Panel>, <Ease of Access>, <Speech Recognition>, <Set up Microphone> Follow prompts and instructions. Once your Microphone is set up, your Skype will work.
Mar 20, 2011 | HP Pavilion dv1000 Notebook
I had this program when I bough hp laptop but I guess after one year later it stopped working and my camera's on skype and chat any program involved with cam don't work! what can I do?
If you are using skype
open skype go to tools from the drop down list select options scroll to audio settings make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment or
control panel sounds and audio devices audio and also voice it
Jan 17, 2011 | Computers & Internet
Microphone stopped working
Since it was working fine>Try to perform system restore >If that does not fixes the issue.
Check the Micro phone with the diff unit to check whether its healthy or not>If the mic working fine with the diff unit. It could be some thing with some settings.
If the Microphone not working on diff unit as well>OF course its an issue with MPhone
Jul 03, 2009 | Computers & Internet
Hello.
1. Audio settings all versions
Skype:
Skype-->Main window…..>Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard (AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
2)Check if your micro (pink) and speaker (lime) jacks are really correct and fully inserted!
They sometimes stuck.
For test only you can use earphone instead of microphone for Line In.
Standard micro in Line In will NOT work.
Go to:
Start
Programs
Accessories
Entertainment or go to
Volume Control; right click on loudspeaker icon in Task Tray
Options
Microphone
Scroll down
Check "Microphone"
If the bar "Microphone" is available, the microphone is detected by Windows now go on
(If not, Windows has a problem with your microphone)
Just to check if your microphone is broken or bad, you can use your headphones instead. They really work!
Which one L or R is microphone now, I think it's L
Check "Advanced properties"
Check Micro "Advanced"
Open
Check "20db boost" or "1.MIC boost" depending on language version
Volume level can be left in any position.
Mute microphone!!!
3. Check audio now on windows base.
Start
Programs
Accessories
Entertainment
Soundrecorder
4. Once done, test with Skype Test Call echo123.
Good Luck
Please Vote.
Jun 17, 2009 | Dell Dimension 3100 PC Desktop
V6105NR MICROPHONES DO NOT TRANSMIT
Does your microphone work with other applications.  If you are running windows XP, go to Start>all programs>accessories>entertainment>sound recorder.  Record your self and play it back.  If you can hear yourself, then the issue is with skype.  Make sure you go through the audio setup wizard in skype to get the best preformace out of your microphone.  If no other programs work, then you may need to reinstall the drivers for that microphone and try it again.
Mar 04, 2009 | HP Compaq Presario V6105NR Notebook
I have no sound on my lifecam vx-3000. What is the fix for it? Does anyone have ideas? thanks!
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Also
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
Hope this helps. Bud
Mar 01, 2009 | Microsoft LifeCam VX-3000 Web Camera
Microphone just stopps working out of the blue
try this on both computers:
first solution:
go to start
control pannel
click on audio
make sure that a mic is selected.
second solution:
double click on the small spkr icon at the end of ur taskbar
make sure ur mic channel is enabled
Nov 15, 2007 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
90 people viewed this question
Alun Cox
David Payne
David Payne
