Question about Maxtor DiamondMax 10 6L300R0 (6L300R020PK) 300 GB Hard Drive
My Device Manager sees my Maxtor Diamond Max 10 Model 6L300R0 hard drive, but my Bios doesn't. I'm using it in a USB configuration. Any suggestions? If my partition is unrecognisable would this cause the problem? If so how can I recover my datafrom this drive? Thanks for any help.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
Yes, If your partition isn't being recognized than windows has no way of reading the information. thats why windows create partitions to determine the amount of space and data being used. it anything try to access it in my computer and see if you can. if you can its possible to get you info, i recommend ananother external to transfer the data to or if its not that much info put it on a flash drive
Posted on Jun 17, 2009
Hardrive is unknown device in bios
The BIOS determines the maximum size hard disk the computer can support.
The max hard disk size for this model Dell is 80Gb.
To use your 250Gb hard drive, install this Hard drive into an USB hard drive case and use it as an external USB hard drive.
Mar 09, 2013 | Computers & Internet
Trying to get my maxtor II to work with windows 07 software but it wont read the usb connection? After i have installed the software for maxtor.
Check Control Panel, System, Device Manager and make sure windows see's the connection. If you see a yellow triangle, that means the drivers are not correct. If you don't see it at all, that is a problem. Give Maxtor a call. You may need to update your motherboard bios, chipset drivers. At worst, you might have a problem with the motherboard or maxtor II device.
Feb 26, 2010 | Maxtor Shared Storage II N01R010 1 TB USB...
Jumper settings
25870e5.jpgCheck this diagram. it shows all configuration in detail..
good luck!!
Jan 02, 2010 | Maxtor Hard Drive
Maxtor 6L300R0 External Enclosure Problem
It may be a power supply issue but before you take it back to exchange see if any of the hints below are of use.
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Oct 05, 2009 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
Windows xp shows hard drive as 30g. I have diamond max plus 9 120gb model 6y120PO s/n y25W76E bios shows maxtor 6y120PO capacity 33821mb
It is probably partitioned. Right click on "my computer" select "Manage" and then look at the disk manager. You will find that the rest of the drive is there, but un partitioned and un formatted.
Jul 11, 2009 | Maxtor DiamondMax Plus 9 120 GB Hard Drive
Hard drive connects and then disconnects quickly
Sounds like a bad solder joint or break on the circuit board. If the data on it is important, you may need to use a data retrieval service.
Jan 18, 2009 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
Can't access Maxtor Manager on 250GB Maxtor Basics portable USB
ANY WAY I WOULD JUST LIKE TO KNOW WHY U WANT TO USE MAXTOR MANAGER..
IF U JUST WANT TO WORK WITH THE HARD DISK U CAN GO TO DISKMANAGEMENT AND INTIALIZE THE HARD DISK AND IT WORKS NORMAL IF U NEED THE MAXTOR MANAGER JUST TRY TO FIND THE APPROPRIATE ONE FRO THERE SITE WHICH MATCHES YOUR HARD DRIVE MODEL.
GOOD LUCK
Jan 01, 2009 | Computers & Internet
Maxtor hard drive needs a chip replacing
Unless you can find the matching chip and are good at soldering these small parts, it can be replaced.
Typically, I would suggest looking for busted harddisks (of the same model) and if their board was still good, just do a direct swap. I did this for a Fireball model HDisk.
Or if their board is busted, you can get the chip from them and, like I said earlier regarding soldering, solder it onto your Hard disks. This is considering that the only part busted was this chip.
Jan 21, 2008 | Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB...
Maxtor DiamondMax 10 6L300R0 (6L300R020PK) 300 GB Hard Drive Logo
175 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
