My inside air conditioner fan isnt turning on whats wrong?
I turned my air on for the first time today this summer my outside unit works fine but the inside unit that blows the air through the vents shut off it came on at first an ran for a while then shut off
    Sergeant:
  • 340 Answers
If the in side blower motor turns off with the out side unit normal operation if the thermostat in the auto position set for cooling If the out side unit run with out the in side unit the out side unit will be wrecked . sounds like you need service and have it cleaned for best performance . Tom
Posted on Jun 17, 2009
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Jul 10, 2012 | Heating & Cooling
My fan and heater work fine, but today I turned on my air conditioner for the first time this year. It did not feel like it was getting cooler so I went outside and noticed that my outside unit was not...
You had a refrigerant release. Probably two lines rubbing together in the outside unit. I have
repaired several of these with this problem. It involves repairing the lines by silver soldering
then pulling a vacuum/ purging with nitrogen and installing a filter dryer and recharging
system. Several hours work, and you must have a licensed tech do this as refrigerants are
involved. Luckily you were able to shut it down quickly (this helps).
Feb 22, 2011 | Carrier 36KCARMS Air Conditioner
Outside unit kicks on but inside fan sometime works and sometimes won't and i have replaced thermostat to get to work i have to turn the fan to on and back to auto several times and finally the fan inside...
Goodman air handlers (inside unit) fan have a delay timer that turn on the fan ,sometimes up to 3 minutes after the outside unit is on,this makes the a/c more efficiency.
Sep 19, 2009 | Goodman CKL36AR36 Air Conditioner
House HVAC Not Blowing
If the outside unit is running and the inside unit is not, probably a problem with the fan motor itself or its capacitor. If you have to have someone repair or replace the fan $200-$250 with parts, a capacitor for a service call and part $100 or so. Check it yourself first to see if there is anything obvious broken wire, hot connection, etc if you feel safe doing that. Turn the power off first. There is also a chance the thermostat could be the problem. Have you tried running the fan on the thermostat "fan on" setting?
Jul 01, 2009 | Goodman Heating & Cooling
Fan motor comes on, however, when a/c is turned on, breaker pops
If the unit is working fine in heat mode and in fan only mode, you have a short in the wiring going to the ouside unit. If it were a fan relay, then everytime the fan came on the breaker would trip. But either way, there is a low voltage short taking place in the unit. If the compressor was bad, the indoor unit would run fine and would only blow the breakers to the ouside unit. I had a unit last summer that did the same exact thing. After I replaced the control wiring to the outside unit, everything worked like a charm. Good luck!
Apr 04, 2009 | GE Heating & Cooling
Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Dec 29, 2008 | Carrier 36KCARMS Air Conditioner
Air conditioner not working
This is simple , turn your thermostat to fan only and not auto fan and see if it runs, if does then run it like this till a service man arrive, the fan motor for cool is gone out!
Sep 08, 2008 | Heating & Cooling
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
165 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
