Apple iPhone 5 Logo
Matthew Bornstein Posted on Apr 08, 2014
The volume on my iphone 5 is not working
I don't have a way of increasing the volume on the videos playing and the ringer icon does not show the volume level.
Hanan Marton
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 31 Answers
  • Posted on Apr 08, 2014
Hanan Marton
Contributor
Level 1:
New Friend:
Cheetah:
Answers
31
Questions
0
Helped
1623
Points
34
I can safely say you connected your iPhone to a speaker dock sometime in the past.
When connecting an iPhone to a speaker dock, the volume control is set through the speaker and not through the iPhone.
Sometimes after unplugging the iPhone, the iPhone keeps thinking that it's connected and won't let you change the volume through the iPhone.
To fix this - simply plug your iPhone to a speaker dock again and unplug it until you can manage the volume with the iPhone.
  • Hanan Marton
    Hanan Marton Apr 08, 2014
    Or... sometimes it's just dirt in the connector that makes the iPhone think that - just clean the connector
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Apr 13, 2009
SOURCE: LOW VOLUME TO HIGH VOLUME
Is this for a specific ringtone or all ringtones on the phones?
Certain versions of the iPhone firmware have an issue where the volume keeps decreasing. Try this to fix -
1. Press the sleep button on top of the phone
2. Now press the home or sleep button so you see the "lock screen (the screen with the wallpaper that has the unlock slider)
3. Double click the home button and the ipod controls should come up on the screen.
4. The volume is probably set at the half way mark...set the volume to full.
See this fixes your problem?
Anonymous
  • 21 Answers
  • Posted on Apr 04, 2009
SOURCE: everything on my 3G iphone works except the phone will not work
try restoring the phone in itunes.
Anonymous
  • 21 Answers
SOURCE: iphone volume keeps appearing
have you tried restoring the phone or turning it off and back on?
menachem rivkin
  • 25 Answers
  • Posted on Mar 31, 2010
SOURCE: My iphone doesn't ring or vibrate, but does with earplugs on.
hey bro,
i fix more problem like your's. by change the flex up. with volume+vibrat button+headphone.
change this and all your problem will be good.
memeh Fixphone
Anonymous
  • 89 Answers
  • Posted on May 13, 2010
I would try a system restore, plug your iPhone into iTunes and click restore, it will delete everything but once its done it will restore it to when your last sync was.
2answers
How to fix ringing sound on iphone
Just goto settings, sounds, increase volume if physical volume buttons will not work. Goto store download volume app and just increase it.
Oct 30, 2018 • Cell Phones
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
2answers
I cannot increase ringtone volume
i had the same problem are you any good with electronics?? if so got to Ringer Loud Speaker Replacement Part Brand New for iPhone 4 4S this is the part you will need and to replace it got to
iPhone 4S Speaker Enclosure Replacement its fairly easy just be sure to read the instructions twice before you start
hope this helps
2answers
How do i increase the volume
Download vs volume and try that
1helpful
4answers
Why is it when people call me my iphone 5 does not ring, how can i make it ring?
check the left side of your iphone and see if the ringer button is down then raise it up and increase the sound volume. Or go to settings then sounds and check the sound level. Else try to restart your iphone if it doesn't work then the problem might be in your iphone speaker.
2answers
The sound on my iPhone suddenly stopped working, it does not work for music like pandora, videos, youtube, police scanner, the ringer fully works and I can hear people talking when they call so I do n
Try resettin, hold home button and power button for about 25 seconds, if this doesnt work the speaker prob went out. they have two speakers, one u hear people on and the one u hear music from.
Nov 01, 2012 • Cell Phones
Don't know how to increase the ring volume?
To increase the volume for the ringer, the volume buttons located on the charging stand can adjust the volume. To change the ringer volume on the phone instead of using the stand, go to the menu on the phone and type 1 then 1 again. This will take you to the ringer volume screen. You can select between the options:{1}: Low {2}: Medium {3}: {0}: Off.
2helpful
How can i increase volume for mic iphone 3gs or input volume during calls..they cant hear me clearly..thats my phone problem..iphone 3gs..
Hello
1 .You need to confirm if its the volume or the mic of your phone that has the problem.
2 .If its the mic,your callers would not hear you but you would be able to hear them.
3. You can Adjust the volume of your iPhone by depressing the volume button on the left edge of the phone, close to the top. This will cause a volume indicator to appear, superimposed over the other icons on your screen. This will increase the volume of your ringer. If you wish to adjust the volume of the phone speaker, use this button during a live phone call. You can also control the volume of your speaker when you are using your iPhone as a music player in the same manner.
4. If its the mic,remove the iPhone from the case, as your case may be blocking the device's microphone.
5. Plug the iPhone device cable into the iPhone and into the computer's USB port.
6.Launch iTunes. Click "iPhone" or the device's name in the sidebar in iTunes and click "Summary then Click "Check for Update" and "Download and Install" to update your iPhone's OS.
7. Remove the device cable after the update finishes and insert your headphone jack into the iPhone's headphones port,tap "Phone" on the home screen, tap "Contacts" and tap a contact to place a call.
8. Press the "+" button on the microphone to increase your microphone's volume.
9. If the problem persists take your iPhone to your local Apple Store for professional service.
BEST OF LUCK
Dec 15, 2010 • Cell Phones
2helpful
2answers
How to increase the sound
To increase the sound of your motorola MOTOZINE ZN5 cell phone.
You can increase the sound of your phone in three categories.
1. music volume,
2. ringer volume,
3. keypad tone volume.
To increase the music volume, you go to the multimedia, select sounds, once the song is playing then you click on the up button that is by the side of the phone. You can increase it to the volume that pleases you.
Further means to increase the volume of your phone is that you go to the 'menu', click on the 'settings', select the 'profile', select 'personalize', a page will show up with a list of data that can be changed on the profile, select the ringer volume, keypad tone or whatever sound you want to increase and increase it with the direction button pointing upward that is by the side of the phone.
To increase the keypad tone, from the home page, click on the up button that is by the right side of the phone, the volume of the phone will increase.
Take care
Backberry 7290 Ringer Volume
Click the PROFILES icon and set the unti to LOUD :)
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
