Question about iLO (2 GB) MP3 Player
Ilo red player
I put in a new bat. and i will turn it on and it will light up and in a few seconds it will turn right back off. Its not locked.
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
Brand New Playstation 3 (just bought today) Turned on for a few minutes then screen went black. Red light flashing. I turn it off turn it back on and it turns green for a second then back to flashing red....
Take the unit back to the place you got it. If you want to check the cables, that is the only other thing you can do without warranty void. Make sure all cables are seated by removing and firming placing them back into their sockets. IF the problem stil occurs, there can be overheating, hdd issues, brrom issues or more.
This is not a good sign off the bat. i woudl just take it back for a new one. cause the other route is minimum of 150$USDish for sony repair or attempt yourself. Since its new return it for another one.
Jun 13, 2010 | Sony Playstation 3 (PS3) Console
Ilo 2 GB Flash mp3 Stuck on ilo screen.
link your USB port between Computer and ILO player.
1.Click on START at lower left corner on you computer. choose "Explore"
2.look for ILO driver on start manu on left hand side. left click one on it. right hand click you will see the drop down options
3. Choose "Format" BESURE that you are going to format ILO NOT your hard drive. it will ask you again that you really want to format it. "yes"
4. copy new mp3 files to ILO. That will be finished. you can start playing it again.
Hope this help.
Jul 13, 2009 | iLO (2 GB) MP3 Player
Cant take reddmango mp3 player off shuffle
If it's on shuffle, hold down the - key and then press +. It will put it back on to sequential. (Just tried it and it works!)
Mar 19, 2009 | Audio Players & Recorders
It wont turn on
Well, you can either try another AAA battery, or buy the same MP3 from a different store.(Be careful, some stores stock defects of items, such as MP3's.)
May 17, 2008 | iLO MP3 Player
Ilo mp3
I have had the ilo for about five months. I have changed the battery several times. The only thing that happen is the back light comes on just blinks! What can I do to correct the problem.
Apr 10, 2008 | iLO (2 GB) MP3 Player
Junk tv
My ilo 27" tv did the same thing (red light on front but would not turn on) and after much frustration looking around on the net I finaly cracked it open. After removing enough screws to remove the back the first thing I saw was the main power board. This board has quite a few capacitors on it and I found 4 of these that had bulging tops. 3 were 1000uf/16volt and 1 was 470uf/16volt. I disconnected all wire connectors from this board and replaced them with parts from radio shack PN 272-1032 and 272-1030. The voltage rating of these are different but ok if larger than the original part. It fired right up when I put it all put back together
Apr 02, 2008 | iLO V27DMBX Television
Stuck on searching files
Take the battery out for a second and put it back in
Sep 20, 2007 | iLO (2 GB) MP3 Player
Sorting... sorting...
If the player allows you to add music on it via USB as a Removable Disk, then copy all the music off the player onto your computer and then format the MP3 player by right clicking it in "My Computer" and going to "Format...". Start it up without music and see how it goes, if it doesn't turn itself off, fill it with a little bit of music, then a little more until you either put your music back on, or until it screws up again. Good luck!
Sep 05, 2007 | iLO (2 GB) MP3 Player
Bought last night--won't turn on!!
I know this isn't a very technical solution, but since you just bought it last night, I would take it back to Wal-Mart and exchange it for another one and see if you have any more luck with the new one.
Jul 28, 2007 | iLO (2 GB) MP3 Player
Help me fix my daughters ilo MP3 player
if either the power button or the lock switch or used while its loading the player will reload or shutoff
Apr 30, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
16 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
