Question about HP Photosmart M547 Digital Camera
Battery life very short
No firmware updates - already using high quality NiMH batteries, LAME dont buy this camera.
    Sergeant:
  • 321 Answers
Buy sony canon model cam
Posted on Jun 18, 2009
Have a nikon D80, sometimes when turning on and taking a photo the battery drains to no charge. have to turn off and back on again and camera works ok. have tried on existing battery and on a brand new...
HI,
You can try updating the firmware if it is possible first.If this doesn't help then try removing the batteries off the camera and allow the camera to reset for an hour and then put them back.
If this doesn't help then You need to use 2500 or higher rechargeable batteries - as soon as you switch to this type of battery, it will work fine!
Your camera requires four AA size batteries.There are several factors that contribute to battery life:
NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges).
Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting.
Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed.
Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries.
Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Goodluck,
Please don't forget to rate the solution as fixya..
Apr 08, 2008 | Cameras
I use aa battery's in my camera but they only take 5 to 10 pics at a time.......is this normal or is something wrong like maybe a setting or something? what should i do to fix this?
Digital cameras in general use a lot of battery power; this one in particular is noted for short battery life. When it was new, this camera was supplied with a Lithium Ion battery for longer life; if you're using regular AAs, the battery life will be disappointing. Oh, and cheap batteries from the dollar store might not even work at all!
The most cost effective solution is probably high capacity NiMH rechargeable batteries; get a set of four so that you can have spares on hand. If even that isn't acceptable, look into getting the Lithium Ion one.
If you bought this camera used, the short battery life could easily be the reason the original owner got frustrated with it.
Jan 21, 2011 | Kodak EasyShare Z712 Digital Camera
I have to change batteries in my Canon A710 after 5 - 10 pictures, what can be the broblem and how to fix it?
Buy the best quality batteries, but NOT the highest mAhr ones. They are designed for long usage for low drain applicaions but may not be able to deliver the high currents required by digital cameras. 2100-2400mAh is said to be best. Also, use a good quality charger that can discharge and slow recharge to reconditionbatteries. I recently bought a Maha charger and some Imedion batteries. Now my camera works as it should. (previously it lost the auto-focus after a few shots). A bit expensive but cheaper than a new camera!
Dec 26, 2010 | Canon PowerShot A710 IS Digital Camera
GoPro freezes
I suggest checking the firmware version of the device vs the latest available on the website and update if necessary. Make sure to have battery charged.
Oct 09, 2009 | GoPro Digital Hero
Battery life
Try buying very high quality recharable batteries. You might have low quality batteries and the camera eats the battery up quickly.
Jan 20, 2008 | Fuji FinePix S3000 Digital Camera
OBSCENELY short battery life in PowerShot A40 :-(
You need to use Nimh battery specifically designed for digital
camera use with high ampacity usage.
Jan 05, 2008 | Canon PowerShot A40 Digital Camera
New Rechargable Batteries Die after A Couple of Pictures
Hi Scorps1, You can solve the battery problem by updating the firmware for the camera. You can find it at http://www.kodak.com/go/c340downloads Please let me know if you have any problems, and let me know if it fixes it. Best regards, nightdiver
May 28, 2006 | Kodak EasyShare C340 Digital Camera
HP Photosmart M547 Digital Camera Logo
113 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
