Question about RCA Televison & Video
Shut off and buzzs will come back on - RCA Televison & Video
  • 668 Answers
Many of the RCA sets made over the last 10yrs have had issues
with intermitent solder connections in the Horizonal circuit, especially the coil off the collector of the Horzonal Output Transistor. Loose solder connections in the Powersupply also have been a problem.
Hope this helps,
Skyassoc
Posted on Jun 17, 2009
Washer will fill and then buzz and shut off. When shut off and then back on it will buzz and then shut off. What can I do.
Motor sounds faulty. It could be jammed, you will have to take a look & see if anything is fouling the motor.
Apr 29, 2016 | Washing Machines
FMV152KWA microwave buzzes when not running
Missy Uhland Bauman,
I understand that you are hearing a buzzing noise from your microwave, even though the door is shut and and it is not running. I would suggest to give the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back. If you are still hearing a buzzing sound, I suggest either contacting the manufacturer or your local authorized technician.
-Best Regards-
Jan 10, 2014 | Frigidaire FMT118E1B Microwave Oven
My sanyo hdtv wont stay on
I once had an HDTV with this same problem. If I turned it back on, it would make a loud BUZZ-BUZZ-Buzz noise for about twenty seconds before coming back on.
I can only guess that the problem is the TV drawing too much power from a circuit that can't support it. Do you have many electronics plugged into the same socket? Is the TV going into a splitter? Try isolating the connection and the TV might have better luck. No guarantees however.
If it's the same problem I had, then it will do this no matter what you hook up to it, as you seem to have at least partially discovered.
Jan 30, 2018 | Televison & Video
My 99 yukon just shut off while driving and wont crank back up
If the engine cranks. Possible fuel pump not working.. Turn key and have someone listen at the filler cap to listen for the fuel pump buzz.. If no buzz fuel pump bad
Jan 06, 2011 | 1999 GMC Yukon
Quinny Buzz seems to be locked up and will not fold. The screw on the long part of the chassis is loose
i have a similar problem i cant get it to shut back down extremely stiff does anyone know how to fix it ?
Jun 22, 2010 | Quinny Buzz Three Wheel Stroller
3 lights blink and a loud buzzing sound.
Color wheel you can get one at the following link with instructions on how to replace it
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Says card cover open when turning on.makes a buzzing noise then shuts back off
you should have either dropped it down the floor or it should have been affected with water or solvents. the only way is you have to take it to the service centre to change the lens array.
May 27, 2009 | Olympus FE-20 Digital Camera
Dryer only works for about 20 minutes, buzzes then stops.
the dryer is over heating up due to a blocked steam pipe , fluff build up inside the dryer. I have a dryer that id the exact same thing , found out it covered in fluff though out the whole dryer , motor and element ..
Jun 21, 2008 | Dryers
My Camera
That is not a good thing, try and take it back where you Purchased it, the Memory might just need to be reset, and that should do it,but let the Dealer do it, just in case..
Happy Holidays
Bobby
Dec 08, 2007 | Casio Exilim EX-Z57 Digital Camera
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
