Question about Apple iBook G4 Mac Notebook
My IBook G 4 reads error when connecting to my son in laws wirele
"error in joining the AirPort network"
Help.
Andy
  • 44 Answers
You will need to check if the internal wireless antenna is plugged in to the wireless card. First, touch some metal or wear an antistatic bracelet, then pull on the two tabs on the top row (F-keys) of your keyboard. Lift this up. Then, look for a cable with a round, 5mm diameter plu on it. Plug it into the slot on the top of your wireless card. That should fix it.
Posted on Jun 21, 2009
Airport sign in keep saying wrong password
Delete Preferred Network(s)
  • System Preferences > Network > Select AirPort > Advanced > AirPort tab
  • Under Preferred Network, use the minus button to delete the network(s) you regularly use from the list
Delete AirPort Keychain Entries (Note: only applies if you connect to AirPort/Time Capsule routers)
  • Launch the "Keychain Access" application located in /Applications/Utilities
  • Click on the "Kind" filter at the top, and look for any "AirPort network password" entries...and delete them.
  • Restart, or log out then back in.
Add Preferred Network(s)
  • Under Preferred Network, click on the plus button to add any preferred network(s).
  • Restart or log out then back in.
Jul 02, 2014 | Apple iBook G3 Mac Notebook
How to connect my hotspot to my Ibook g3
Pull down from the Airport icon in the menu bar and select "Join other network..." and enter its name, then enter the proper password. Your hotspot's name and password are on the box.
Any Wi-Fi station can be configured not to display its name. Hotspots generally come configured this way out of the box.
--Gil
Feb 19, 2014 | Computers & Internet
My ibook won't connect to the intervet via airport or the ethernet
In your stage you can do this simple things.1. update your software call SOFTWARE UPDATEif the problem with network drivers after this step will solved it2_14_2013_7_00_24_am.jpg
2. Still the situation same... Reinstall with Install and Restore disk which came with the iBook (OS X 10.3 or 10.4).
Feb 13, 2013 | Apple iBook G3 Mac Notebook
Ibook wont log onto my network
I ran into this with my home network and my old g3 ibook needed the older speed wifi to connect. I found my old wifi router, hooked an ethernet cable to the newer router (in a regular ethernet port) and connected the other end to the internet port on the old one... they linked and worked fine to provide wifi for the old G3's ..
Dec 19, 2009 | Apple iBook G3 Mac Notebook
Ibook g3
First of all, you need an Airport card for the iBook G3, chech for example this link; http://popular.ebay.com/ns/Computers-Networking/Original-Airport-Card.html (you should buy one like this: 9deeeda.jpg
, there is a G4 card too, but your iBook doesn't support this one).
Next, install it;
Then, buy a wireless router that uses 802.11b/g or 802.11b. This is very important because your airport card doesn't support 802.11g, and install it, but don't protect your network with a WAP password, your iBook doesn't support this, but use WEP.
Then start your iBook, and click on the Airport icon in the right corner, select your network, type in the password and it will work!
Jul 01, 2009 | Apple iBook G3 Mac Notebook
My clamshell ibook shows signal but won't load sites...
Try with Safari or Firefox. If still no pages loading then your Airport is not connecting to the Internet. If you are using a cable modem contact your ISP for assistance.
Jun 29, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Ibook G3 not conecting to internet
that just means it cant find it you need to try other setting and create a network connection,
it should see the network cable straight away try diff port on the router then dial up the ip address of the router first and change the setting . ip like 196.162.0.1
actionmab
Feb 24, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Ibook g4 freezes and airport problem
have you gone into airport utility?
are you using an airport extreme? if so, reset it.
then delete the current wireless network, and try setting up a new one in airport utility.
Feb 16, 2009 | Apple iBook G4 Mac Notebook
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
Apple iBook G4 Mac Notebook Logo
59 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
