Question about GE (PSS26MSRSS) Side by Side Refrigerator
ICE MAKER STOP WORKING
NO WATER TO ICE MAKER. VALVE NOT WORKING, VALVE GOOD , ICE MAKER GOOD. IS THERE A RELAY BETWEEN VALVE AND ICE MAKER ?
    Habit-Forming:
  • 174 Answers
The water comes in from the wall and then it run to a solenoid then to the ice machine.the timer on the ice box tells the solenoid when to open and close,
Posted on Jun 17, 2009
No water no ice
Change the=> 67006531 Water Inlet Valve I believe the side of your 67006531 Water Inlet Valve that controls water flow to the ice maker has weakened and cannot open properly. Replace the water valves and I believe the ice maker will work fine, Sea Breeze
Jun 07, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Ice maker quit, does the power start relay control the water valve
Hi
If the ice maker has completely stopped producing ice ….
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
If the ice maker is producing ice poorly ….
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Sep 01, 2010 | Kenmore Refrigerators
Ice maker stopped working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Mar 02, 2010 | KitchenAid Architect KBRA20ERSS Bottom...
My freezer deparment does not make ice cubes. no water enters the ice cube maker
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 06, 2010 | Kenmore Refrigerators
Ice maker not working
Cause could be the solenoid valve which controls water flow into the ice maker.
Could be bad solenoid, bad relay for solenoid, clogged solenoid valve, corroded electrical connections, etc.
More info? Let me know...
Charlie
Aug 14, 2009 | Refrigerators
Ice maker is not making ice
Is the freezer at least 10 degrees or colder.Is there ice in the ice mold? If no water Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jul 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker goes through the process but no ice is produced water
If you're not getting water to the ice makerTry swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
A strainer before the inlet valve can also get stopped up restricting flow. ice maker
Jul 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My maytag ice maker is not working, but the water dispenser is working at a good pressure.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze and block the tube. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Refrigerators
Water wont fill ice maker
the relay is the ice maker , buy the kit that contains the valve and it is a complete new ice maker system.
easy to find at sears parts.
Phil
Jun 11, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice maker in Kitchen Aid stopped making ice
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
195 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
