Question about Rockford Fosgate 800.2 Car Audio Amplifier
Power light vs. protect light mode
I have a general question..i never paid attention to the light on my amp...when i hooked it up after a couple years, there's a red light on, on the center of the amp in its emblem/lable....and i was wondering is this the power light or the protection mode light?  Because a while back my sub shorted due to a crimp from my speaker wire which was cause by my backseats folded down to the trunk area...it shorted out the subbed and i saw the short on the speaker wire as well...i don't know if my amp was shorted out or not, b/c i took everything out and never messed with the amp til now....just wanna see what you would normally look at if you were looking at the amp to see if it's working properly..i opened it up and couldn't find anything wrong.  Does the amp have a separate fuse for it?...and one more question, if i was to hook up a sub to my amp to test it out...would it endanger my sub and cause it to short, is that possible?  please let me know ---thanks
  • tranlich Nov 01, 2007
    thanks, I'll try out your suggestion and measure the DC voltage
    thanks for the tip, i'll try it out and let you know
  • 631 Answers
If the power light on top of the amp is on, the internal power supply is operating.
It is possible that the amp could damage the speaker if it has blown output transistors. Before you connect a speaker to it, you should measure the DC voltage across each pair of speaker terminals. If the DC voltage is more than a fraction of a volt, the amp needs to be repaired.
The amp requires an external fuse. Download the owner's manual from the rockford site.The correct fuse for the amp will be specified in the manual.
Posted on Nov 01, 2007
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Mar 01, 2012 | MTX Thunder® TC8001 Car Amp
How do i get it out of protect mode?
if your in protect mode then it is because of couple things one the ground wire is not properly grounded or two the amp is overheating also if the amp gain is way to high it will throw the amp into protective mode try these see if fixes it
Sep 25, 2010 | Car Audio & Video
I hooked up 2 capacitors into my amp and every time I put power to it the amp shuts off and 10 seconds later a red light comes on for 5 seconds and the amp don't turn on, basically it goes into protect...
Well, I have no idea why you would have two capacitors on a 500 watt amp but, did you charge the capacitors? Have you tried the amp without the capacitors? What size power wire are you using?
Sep 20, 2010 | Kenwood KAC-9102D Car Audio Amplifier
I have a dual electronics 4 channel amp that goes into protect mode as soon as i throw power to it
unplug all the speaker from amp then power on. if you still have a protect light amp is bad and if you have no protect light continue to hook up each speaker one by one while amp is on till you get a protection light and that speaker would be the source of your problem
Jun 02, 2010 | Dual Car Audio & Video
My amp is a kenwood kac-9152d it goes in to protection mode soon as you hook up the power
In protection mode do you mean the light comes on and it plays music and stuff? If that's the case, that's what the amp is supposed to do. Protect itself from a power surge
Feb 21, 2010 | Kenwood KAC-9102D Car Audio Amplifier
Green light (protection mode) on, NO red light (ready)
double check your wires aren't shorting out or power or remote wires aren't grounding. check if speakers are blown with nine volt battery
Sep 05, 2009 | Kenwood Car Audio & Video
Protection mode on my amp
YEA CHECK THE OHMS ON THE SUB TO MAKE SURE THEY MATCH UP TO THE AMP JUS SOUNDS LIKE THE WIRING IS OUT OF PHASE.
Jun 15, 2009 | Pioneer GM-7200M Car Audio Amplifier
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
Jensen 400W A400HLX Power Problem
If the amps are going into protect mode, it's likely that the output transistors have failed in both amps. This can be due to many things. Generally it's caused by running the amps at too low of an ohm load. If you drive the amps hard on a daily basis, that can also cause the amps to fail prematurely.
Let me know if you have any other questions.
Sep 22, 2008 | Jensen A400HLX Car Audio Amplifier
Protection mode on Lanzar Vibe 241
Almost without exception, if the protection light comes on as soon as you power it up, the output transistors are defective. Any reputable repair shop that services car audio equipment should be able to repair it.
Oct 06, 2007 | Lanzar VIBE241 Car Audio Amplifier
Rockford Fosgate 800.2 Car Audio Amplifier Logo
290 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
