Question about Toshiba REGZA 47HL167 TV
I have a Toshiba Regza 42HL67 made in Aug 2007 and got it used would like a owners manual to know what all it does.
  • 2,336 Answers
Click here to download the user's manual.
Posted on Jun 17, 2009
Why is the t-con board in my Toshiba Reza 42HL67 LCD TV repeatedly dying?
Could be just bad luck! It seems unlikely to me that the power supply would take nearly a year to destroy the T-con board!
You could get in touch with Toshiba to see if there is some kind of problem that is cropping up on this model that might cause failure in on the T-con.
May 19, 2016 | Toshiba Regza 42hl67 42-inch 720p Lcd Hdtv
What is the best converter box to use with toshiba regza 42hl67 flat screen tv?
As far as I can make out, this Toshiba model is made for the US market so doesn't actually have a freeview tuner. It will only receive satellite and cable HD signals and local US TV, all of which has to be bought. You need to get something like an August DVB400 - HD Freeview Set Top Box -Digital PVR Tuner with USB TV Recording, eBay would be best I think, where they are sold for under £30.00. The tuner packed up on my 32" Regza so I bought one of these and it works fine. Plus you can record to a USB stick if you don't want to miss a programme. Hope this helps ......BS
Feb 22, 2015 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How do you change the time zone on 2007 Toshiba Regza 42HL67?
the manual doesn't mention anything about setting the time, so I am wondering if it comes from the cable or satellite box connected to it.
this is how it is done on another Regza model
Setting the time zone
The Time Zone setup will allow you to specify the
correct time zone for your region. This feature will
allow the TV status information to show the correct
time zone information for your viewing area.
From the SETUP menu, highlight TV Settings and
press T.
Press B or b to select Local Time Setting and press
T.
Highlight Time Zone and press C or c to set your
desired time zone.
If you want to activate the daylight saving time,
highlight Daylight Saving Time.
5
Press C or c to select On and press O.
Toshiba REGZA 46SV670U Owner Manual Setting The Auto Input Feature Setting...
your model manual
Toshiba 42HL67 42 LCD TV Service Manual
Jul 24, 2017 | Toshiba REGZA Televison & Video
Need a Owners/Users Manual for a 2007 Toshiba Regza LCD HD TV
Checkout Toshiba.com for manuals and infact any Toshiba product information
Dec 14, 2010 | Televison & Video
42hl67 has a continuous blinking yellow light in 3 blink intervals, how do I fix this?
I followed the steps at the following link and it worked for me. I have a 2007 Toshiba Regza 42HL67, but the firmware applies to many models as documented in the readme file at the location found via the link below. I used a 1gb SD card formatted FAT16, copied the unzipped files and folder to the card (wasn't sure if it required the top level folder or only the files under the top level folder so I copied both to the root of the SD card), unplugged the TV, inserted the card, plugged in the TV, waited 2.5 minutes, unplugged the TV, removed the card, plugged in the TV, yellow light flashed 3 times and went out. I turned on the TV and it has worked normally since last night.
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
May 09, 2010 | Toshiba 42HL67 42 in. LCD Television
I have a Toshiba Regza 42HL67US that I want to wall mount...how the heck do you get it off the stand?
First you should lay the unit face down on a blanket or the like, being careful NOT to damage the screen. I don't have one in front of me right now but if memory serves well, there is a plastic cover on the back side of the base that you can pop off giving you access to the base mounting screws. Remove the 4 screws and viola, the base should slide off.
May 06, 2010 | Toshiba 42HL67 42 in. LCD Television
Toshiba Regza 42 in - have no blue or yellow colors - all green and red - TV was purchased in Aug 2008 - this is a recent problem - changing settings on the color spectrum didn't work
It sounds like you have a driver board problem. I suggest getting in touch with Toshiba and see if they will have it diagnosed/repaired under warranty. If not, they can give you the name and number of an authorized repair center who will know best how to diagnose and repair the problem with those units.
Dec 01, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
REGZA 42HL167 Won't turn on
I found it!!
In my case, the 42HL167, the CPU pcb (most commonly referred to the SEINE PCB) is having issues booting and just isn't starting up.
My friend gave me his 42HL167 after this problem started after a power event during a storm and I managed to fix it by reloading the firmware.
I posted instructions on my website at:
Once I figured out some of the facts, it was a breeze...
I agree -- it seems like a design flaw. What cracks me up is that the places I called for a replacement SEINE PCB require the core (the bad PCB). Well GEE, why is that!?!? EASY FIX MAYBE?
It was. Too easy. Shamefully easy.
-Ben
Aug 18, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
HELP ME PLEASE!!!!
well are using hdmi cables u must get hd box and upconverting dvd player with hdmi cables set britness 50 contrast 65 coler 40 but get hd soreses use hdmi cables
Mar 15, 2008 | Televison & Video
Toshiba REGZA 47HL167 TV Logo
430 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
