Question about Toshiba TP55G60 55" Rear Projection Television
Toshiba TP55G60 shuts down and red light blinks
My Toshiba TP55G60 will shutdown almost immediately after start-up then the red light on the front panel begins to blink. Nothing will work until the unit is unplugged and replugged in. Sometimes it will start rigth back up, sometimes it will imediately shutdown again and sometimes it will stay on for a few minutes and then shutdown. In all cases I have to unplug it to get it to try to restart. Once started picture and everything else are fine. Problem is getting worse. The unit is 12-13 years old so i dont want to spend alot to fix, yet the picture is good when it works.
Any help would be aprpeciate.
  • 668 Answers
Check the powersupply for loose solder conncetions. Especially in the protect circuit.
There is a white waffer looking IC that has been known for the pins to pop open from the
high frequency output of the power supply.
The Powersupply is on the right side and pretty easy to tell. Please use caution when
working on this set because the caps in the powersupply can hold a good charge. If you have any doubts about doing it yourself, call a professional and hopefully the pain in the pocket won't overcome the pain threshold.
Good Luck,
Skyassoc
Posted on Jun 17, 2009
62hmx95, blinking light, powers on then off
Examine in order the lamp, the ballast, the fans.
Apr 29, 2012 | Toshiba 62HMX95 62" HDTV
Sony KDL40EX500 shuts down and flashes a red LED 7 times. What does this mean?
This is a issue with the power supply board here is a link that shows you what this blinking light codes mean
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
Sep 03, 2010 | Sony KDL40EX500 40 in. HD-Ready TV
Auto shut off
Nov 24, 2008 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Blinking red light
Your TV is in shutdown. Unplug the set from the wall and wait 30 seconds. Apply power and see if the set comes back on. If the problem is the same (red blinking light) then you need to call a repairman. The most likely suspects are the convergence chips , vertical loss, power regulator or horizontal circuit problems. The shutdown circuit monitors multiple circuits for voltage and current malfunctions. That is why you need someone trained to troubleshoot the problem. Good luck!
Nov 23, 2008 | Toshiba 57H81 57" Rear Projection...
Red Blinking Light
I don't totally understand what your asking, is this a TV, you didn't list the model or make
Dec 05, 2017 | Toshiba TP55G60 55" Rear Projection...
Toshiba projection tv
your set has a problem with the power supply causeing the set to shotdown. You can get a manual called Toshiba shutdown circuits and power supply troubleshooter that takes you step by step to diagnose your model its available at this link they email it to you almost instantly after purchase and they also provide free tech support in case you need further help. heres the link.
http://servicemanuals.vstore.ca/
May 12, 2008 | Toshiba TZ50V51 50" Rear Projection...
TV shuts down with Red Light blinking
Thats an easy set to trouble shoot, but you would need the manual called toshiba power supply and shutdown circuit troubleshooter. It takes you step by step on the items to check so you can easilly pinpoint the problem. You can get that manual at the following link, they email it right after purchase and they also provide free one on one tech support so you can get help with it if you need. Heres the link
May 10, 2008 | Toshiba TZ50V51 50" Rear Projection...
MY tV will not power and red light keeps blinking
http://www.keohi.com/keohihdtv/brandspecific/toshiba/quickfix/flashing_led.html
Dec 05, 2007 | Toshiba TP55G60 55" Rear Projection...
Unplug the TV from the outlet for about 30 seconds. This will reset the microprocessor. Re apply AC and power on the TV. If your lucky the set will come on and play. If not, the red light will start blinking again indicating shutdown. There are many reasons for the set to go into shutdown, but one of the most common cause is failure of the convergence output IC`s. If your TV is in shutdown, you will need to find a qualified technician for proper diagnosis and repair.
Nov 23, 2007 | Toshiba 57H81 57" Rear Projection...
Televison & Video Logo
476 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
