Pretty simple, make sure you unplug the range or flip the breaker off. Remove the two screws mounting the element to the back wall, carefully pull out the element. It probably has slide on connectors, pull them off and thats it! If you accidentally pull off a wire and it stays back in the stove, you can pull the unit out and remove the back panel and it will be all out in the open.
How do I replace the element in my Jenn Air oven? I've got the element, unscrewed it from the back...
(More)
How do I replace the element in my Jenn Air oven? I've got the element, unscrewed it from the back of the oven but I can't see how the piece that connects the element to the wires/back of oven works. Yes, the power is off! The range is not actually the model listed below, it's SVD48600B but that wasn't on the drop down list so it wouldn't accept it.
removing glass door panels on electric slide in range jenn air as they have somehow become stained...
(More)
removing glass door panels on electric slide in range jenn air as they have somehow become stained inside
