Question about Daewoo DW500M Top Load Washer
My washing machine does not clean properly.
I have a frigidaire stacking washer and dryer. The dryer is fine, but the washing machine does not clean well. The agitator works fine, but still the clothes do not come out clean. I washed a pair of jeans in mine and they did not come clean, and then cleaned them in my friend's Inglis machine and they came out clean. Any idea what the problem could be
  • dagmar_v8 Jun 17, 2009
    Hi
    I used the same detergent and the same temperature as my friend and did not load it as full as he did. Could there be another solution
  • 653 Answers
Let's start with the detergent and the water temperature. If they are the same as what you use at home,
then I have to assume the machine may be overloaded. Back off on the load by about 1/3 and see what happens. In the worst case scenario, you could let the jeans soak in the detergent/water mix over-night
Posted on Jun 17, 2009
  • Fahr Quad Jul 10, 2009
    Sorry I haven't been back to you in a while. I have been a bit too busy dealing with contractors to visit Fixya for close to a month. A separate washer typically has a capacity around 3.8 to 5.0 cubic feet (top load versus front load). The washer in a typical stacked set has a capacity around 2.4 to 3.2 cubic feet. Assuming the water to your washer and your friend's washer comes from the same source, running smaller loads and/or presoaking heavily soiled clothing are about the only way you are going to get better cleaning while using the same temperature and detergent. If your friend is using public water and you are using unfiltered and untreated (softened) well water, your clothes will most likely come out a bit dingy compared to your friend due to harmless minerals in the well water (iron, manganese, copper, etc...).
I have a Frigidaire GLET1031 Top Load Stacked Washer / Dryer. The water valves do not work unless the dryer is turned on. Also the washer drum will not spin with dryer on or off and the dryer does not get...
WHat ya need to check is for proper power going to the entire unit it sounds as if either a breaker is off or their is burnt/broken wire from the main power connection.
All symptons listed i suppose occured suddendly?? and to me its a lack of proper electrical power that is causing all of them.
GENE
Oct 03, 2011 | Frigidaire GLET1031 Top Load Stacked...
Won't drain.
check the filter at the botom remove and clean.
CHECK AND CLEAN THE WATER PUMP,
IF IS BAD REPLACE.
Apr 07, 2010 | Frigidaire FEX831CS Top Load Stacked...
The washing machine does not filter out lint. It
I have the same problem. There's a plastic piece top back of tub that says "Clean lint filter after each load", but where is it ?
Mar 14, 2010 | Frigidaire FEX831CS Top Load Stacked...
Unit is shaking off the ground when going into final spin mode
it is unbalanced, you must contact your supplier and have him fit it properly. do not do anything or you will invalidate any gaurantees
Sep 03, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire Stacked Washer and Dryer
check to see that the agitator is spinning out the water, if it is not, you may have torn the wire out of the door switch, which will prevent total water discharge
Jun 11, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Dec 23, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Nov 12, 2007 | Frigidaire GLTF2940ES Front Load Washer
Daewoo DW500M Top Load Washer Logo
1,741 people viewed this question
Top Daewoo Washing Machines Experts
Marvin
Marvin
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
