Question about Samsung AW0693L Air Conditioner
I have a SanSung AirConditioner at a Tower site. I need to fine out a way to make this airconditioner come on when the power comes back on with out sending someone on site to turn it on.
  • 116 Answers
Simplest way is to rewire unit and add a refridgeration type stat to a 115v ac coil contactor or relay toturn compressor on and off and hook up fan on 1 speed hope this helps
Posted on Jun 17, 2009
LG airconditioner with reset botton on power cord 220. After a lightning storm. Airconditioner wont come on.There is power to the outlet but no power in the cord past the reset unit. should I replace that...
Yes replace reset cord. also see an electrician about a surge suppressor for your home this one item will save you alot of money and appliances
Aug 24, 2012 | Heating & Cooling
When the airconditioner is on cool.Water comes from the airconditioner inside and dripping on the floor.
If it's a car air conditioner, your condensate drain line is clogged. If it's a home window unit, it needs to be tilted outward more. The downward tilt should be no less than 1/4" per foot. If your unit is 18" from the window to the back of the unit, the back should be 3/8" lower that at the window....minimum.
May 14, 2011 | Mitsubishi Heating & Cooling
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Uneven air distribution through indoor unit
you should remove the indoor unit and send the gas to outdoor unit and remove the pipe line and start cleaning it.
Apr 10, 2009 | Heating & Cooling
2006 Mercury Mariner
it could be frozeup or blew an outlet valve have some one check coolant levl for the a/c
Sep 01, 2008 | 2006 Mercury Mariner
C6 error on airconditioner
6 - DC Peak Error
• Supplied power is not normal
• Comp Connector (CN-U,V,W) is disconnected or inserted to wrong
position
• Compressor is damaged (coil short) ? replace compressor
• Too much Refrigerant
• Defect in outdoor pcb assembly ? replace pcb assembly
Try turning power off to external unit, usually resets diagnostics and runs OK. If not PCB external unit likely culprit, replace!
Jul 31, 2008 | Heating & Cooling
Samsung AW0693L Air Conditioner Logo
131 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
