Question about Whirlpool LER4634J Electric Dryer
WHIRLPOOL LER6620PTO DRYER TAKES MORE THAT 40 MIN. TO DRY A LOAD OF CLOTHES. WAY TOO LONG
  • 6,784 Answers
Hi, you are correct. this drying time is quite long. i recommend checking the following areas on your unit to combat this issue. the most common issue here will be a clogged vent hose or blower housing obstruction.
Check the following---
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Posted on Jun 17, 2009
Dryer takes twice as long to dry clothes.
Did you check the outside vent? Those get clogged as well.
Oct 27, 2012 | Whirlpool LER7646J Dryer
My whirlpool dryer moder ler6620pto gets hot but clothes are taking to long to dry. it seems to be getting hot enough.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 21, 2011 | Whirlpool Dryers
What is automatic dry miser
What the automatic dry miser is, is a sensor that measure how dry the clothes are and will adjust the time its going to take to dry the clothes throughout the entire cycle. If at the beginning it estimate it will take 40 minutes to sry a load but they are dry in only 25 minutes the dryer knows the clothes are dry and cuts the dryer off. Saving 15 minutes of unneeded gas and electric that it would run and waste power and gas since the clothes were dry already.
GENE
Aug 18, 2011 | Whirlpool GGW9868K Gas Dryer
Takes long to dry clothes
on your side, it is better you don't touch anything internal in the dryer as you can hurt yourself and spoil the device even more. have a professional take a look at it before you use it any further.
Jun 11, 2010 | Kenmore 62802 Electric Dryer
The dryer runs fine with no load but as soon as i add clothes aft
Sounds like the motor may be on its way out. a motor, over time can form a short or require more amps to do its job but can cause the breaker to trip. Also over time, dust and lint can build up over time, inside the dryer and cause it to over-heat.
Apr 26, 2009 | Whirlpool Inglis IP8200 Dryer
New Whirlpool Dryer taking too long to dry
Old dryers worked on the premis, "bake them til they are done". Newer dryers are all about saving energy. Newer dryers rely far more on airflow than thier predecessors. Most likely if your clothes are taking 120 minutes to dry for a new dryer, you have a ventalation problem. Make sure (even if it was "professionally" installed) that the vent from the back of the dryer to your wall in not kinked, bent over, or other wise restricted. Also make sure when the air is venting to the outside of your house you can feel a fair amount of air pressure there. Bulid up over time or even a nest being built in your vent can cause a restriction on airflow. These can be cleaned by a professional service or many appliance and hardware sell cleaning brushes and kits. Worse case scenario, Whirlpool will pay for customer instructs for the first 6 months. So even if they have to come out and tell you it's a problem with your house vent or electrical supply, whirlpool can be billed for this. Of course if there was a manufacture defect off the production line, repairs are still covered under warranty as well.
Jun 21, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
250 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
