Question about Whirlpool Duet GHW9150P Front Load Washer
Control locked My washer is showing control locked and want let me start it or anything can someone help
    Problem Solver:
  • 12 Answers
Hold the padlock button for 3 sec, if that doesnt work replace the user interface
Posted on Jun 17, 2009
Maytag maxima quit part way through a load now won't start
Hold pause button for 3 seconds or unplug for a few minutes v
Nov 13, 2017 | Maytag Washing Machines
My GE Front loading washer has a red lock light
On the GE GFWN1100LWW the Lock light indicates that the Child Lock (Panel Lock) is enabled. Press and hold the Lock touch pad for 3+ seconds. The light will go out. (Note: if you hold that button for too long, the lock will disengage and then reengage.)
The lock is useful to avoid having someone change the settings or start the washer when they shouldn't. (For example, you don't want to start or change the cycle settings on the washer while cleaning the control panel's surface.)
I hope this helps.
Nov 25, 2013 | GE GFWN1100LWW Washer
F 11 code flashing
The F-11 error code is a communication error between the main control and the motor control. I recommend unplugging the washer and removing the access panels.
Fdl error code because it is usually associated with the F11 code. The FdL fault code indicates that you have a problem with the door lock assembly. This is often caused by a failed door lock but it can also be caused by a failed wiring harness connection or in some instances by a failed control board.
Check for damage to the door hook on the washer door and look for anything that could be clogging the catch on the door lock assembly on the front panel of the washer.
You may need to check the wire harness connections on the door lock assembly. The images below show the procedure for accessing the door lock assembly on this type of washer. Be sure that you unplug the washer before accessing internal components.
I have seen the failure be caused by a door lock and a faulty machine control board. A little trick I have found is to remove the top of the washer and push down lightly on the connector that is labeled dls5 this connector should have four black wires. This connector is located on the machine control board under the top. Use an insulated screwdriver to push on the connector and start a cycle. If the door locks and the washer works, I recommend replacing the machine control. It has a bad solder joint on the board. We often see error code F11 also with bad solder joints on the control board. If pushing on the connector did not make a difference, I would suspect a faulty door lock first.
Hope this helps.
Jun 06, 2011 | Washing Machines
WHAT IS A CL CODE ON MODEL 796.41022900 FRONT LOAD KENMORE ELITE WASHER,IT SHOWS INTERMITTENLY DURING WASH CYCLE
Means someone put it in controlled lock position. Just hold the Control lock button down for 5 sec or so until the light comes off. Machine isn't malfunctioning.
Jul 31, 2010 | Kenmore Elite 45986 Front Load Washer
Control lock is lit up and will not go to any
This happens often, pressing buttons, sometimes it can be easy to slide into control lock. I have this link that shows how to turn it off.
http://www.managemylife.com/mmh/questions/193855-how-do-i-disable-the-control-lock-on-my-duet-washer
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE4t Washer - "Control Locked"
Adjacent to the "Control Locked" light is the DRAIN/SPIN button. Push it in and hold for 3 seconds. This should unlock the control panel. If it doesn't, let me know.
This is a designed feature of the washer to lock the controls to prevent small children from accidentally turning the washer on or manipulating the controls in any way. The control can be locked by holding the DRAIN/SPIN button in for seconds, and released the same way. If someone leans against the button this can also occur. Hopefully this will be an easy fix for you. I hope this helps.
Jul 24, 2008 | Kenmore Elite 45986 Front Load Washer
The control lock light is on and won't let me continue or start a next load
To the right of the "Control Locked" button is a "DRAIN & SPIN" button....press it & hold for 3 seconds to unlock the control (that is how someone must have accidently locked it.
Jan 13, 2008 | Kenmore Elite 45986 Front Load Washer
Control lock light
someone has enable the child lock feature. One of the buttons should say hold 3 secs for control lock under its normal function description. Hope this helps
Jan 01, 2008 | Washing Machines
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Dec 29, 2007 | Kenmore Elite 45986 Front Load Washer
Control Locked
you have to push a button on right side which tells you to hold down this button for control lock
Sep 14, 2007 | Whirlpool GHW9400 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
109 people viewed this question
Dan Webster
Dan Webster
Sal De
