Frontloader will not accept hot water despite clear hose and filter, sufficient water pressure and clear filter at back of machine. Thus unable to get a warm water mix. Unclear if temperature switch electrics are faulty. Cold water wash ok.
  • 1 more comment
  • alansden01 Jun 17, 2009
    Ariston Margherita 2000 AB95 Frontload Washing Machine 5kg Purchased new in Australia in 2001
  • alansden01 Jun 22, 2009
    Problem isolated to hot water inlet valve either stuck or solenoid has had it. Unable to safely get my meter on it until removal and may have to replace the 3 valve/solenoid setup as it may be one unit. With hot water only on and machine set to accept only hot water there is humming but no water entering the machine. Would appreciate if you can direct me to links where I may get a schematic diagram of this model or similar without paying for it. Thanks again Allan Smith
  • alansden01 Jun 27, 2009
    I have isolated part and will have it replaced.
  • 334 Answers
Sounds like the solenoid valve that lets the hot water onto the machine may have gone bad. If you have a way to measure voltage, find the valve, it should be close to the hot water inlet. Turn the machine on to fill with just hot water. See if you have voltage at the valve coil. Also, if you are filling with hot water only and there is no water coming in, o rvery little, this leads to the valve as well. If you get all cold water while trying to fill with hot, chances are you have a temperature control problem. Let me know what you find.
Posted on Jun 17, 2009
  • 331 Answers
Yes you can check here www.techray1.com and click ont he guru guy on the left. then you can use repair klinic to investigate. your issue. Hope this helps
please rank
Posted on Jun 22, 2009
  • 6,784 Answers
If possible, i will need your complete model number and, the proper brand name of this affected unit please. This will allow me to accurately state a valid solution.
Thanks
What does the F19 error code mean
For Bosch and Neff washing machines, the F19 error means that the incoming water did not reach the desired temperature in the 'normal amount of time'. This could be due to a fault with the heating system, the sensor, or the communication between the sensor and the main control board.
The issue could also be due to insufficient hot water reaching the washer. Check that the inlet hose isn't kinked and that the hot water shut-off valve is open. Close the valve and remove the hose. Check and clean the filter at the washing machine inlet. Clean or replace the filter at the shut-off valve. Replace the hose only on the shut-off valve and place a bucket underneath it. Open the shut-off valve and check the water flow. Replace the hose if there is limited flow. (Some anti-flood hoses restrict the water pressure when they detect a small leak.) If you do not have good water flow with a new hose, check the flow from the valve itself. Replace the valve or fix other plumbing issues causing the restricted water flow.
If sufficient hot water is reaching the machine, then you have to find the fault in the heating system. If the washing machine is under warranty, contact the manufacturer. If you would like me to search for any available parts diagrams, please add a comment with the model number of the washer.
I hope this helps.
May 26, 2018 | Washing Machines
What does 4C mean during a wash cycle
4C Water is not supplied.
• Make sure the water taps are open.
• Make sure the water hoses are not clogged.
• Make sure the water taps are not frozen.
• Make sure the washing machine is operating with sufficient water pressure.
• Make sure that the cold water tap and the hot water tap are properly connected.
• Clean the mesh filter as it may be clogged.
NOTE
When the washer displays "4C", the washer do draining for 3 minutes. During this time, the Power button is inoperative.
Feb 11, 2018 | Washing Machines
Lg intellowasher wf-t1081tp hot water intake slow.
wich is connecting with inlet hose & inlet valve,,back of the machine,,thre is one filter in side the valve, remove &clean it,,pls
Apr 12, 2014 | LG Washing Machines
On brand new machine the water pressure is ok (not great as we on low pressure) to back of machine but just dribbling out into tub... Model F&P MW612WH 6.5kg
hi - these machines wioll require sufficient pressure to operate - but low pressure to a certain degree should be fine - takes longer to fill..
Suggest you double check the hoses to the right valve hot/cold etc - usually there is a filter on the hose and one on the inlet valve, hopefully its not blocked.
I cannot see any other component that would be faulty - as you say its brand new...
Jun 24, 2011 | Fisher Paykel EcoSmart GWL15
Model LAT8504AAE Hot water pressure has been reducing over time, little by little. It is now only cold water. All house supply line valves are open.
screen in hot water fill hose is probably stopped up.turn water off unscrew hose at both ends check for a screen,if not in hose check at water inlet on washer pop out screen clean under kitchen spayer and reinstall make sure you put hose washers back in the hose ends that should fix your problem!!!
Jun 12, 2011 | Maytag Washing Machines
No hot water
Not quite enough information to go on here ... the machine connects to hot and cold water or cold water only? If cold only, is it designed to heat its own water?
If connected to hot water ... some newer machines are dependent on sufficient water pressure. Check pressure of hot water is adequate at the tap (and that the water is hot). Check for a blocked filter in the water inlet house at the point of connection to the rear of the machine (remove the hose to check).
Mar 05, 2010 | Washing Machines
Model 530 Frontloader - No water
IS YOUR DOOR FULLY CLOSED TRY PUSHING IT IN
May 14, 2009 | Frigidaire Washing Machines
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Apr 29, 2009 | Washing Machines
Lg frontloader, washer is not getting sufficient water. hose is okay, is there an internal filter we can check?
Plug off the wall. Unscrew the hoses that bring water to the machine, check the fine meshes on hose as well as machine, clean out well with tooth brush (not yours), see that pressure is good in your wall socket. Refit carefully, check for leaks.
Feb 26, 2009 | LG WM2487H Front Load Washer
Washing powder residues left in washing powder compartment.
5 bar is a good pressure. worth while to check the valve filter as suggested. turn off water, remove hoses from machine. look down valve spigot and there is a mesh filter inset. remove with small pliers and clean
Jun 09, 2007 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
