Question about Whirlpool Duet GHW9150P Front Load Washer
Only hot water in washer on all settings
When i wash and set the water temp on cold it is hot water that it rinses with even if it is set on cold
  • 109 Answers
Are the hoses connected to the correct inlet valve on the machine?
If so, then the inlet valve itself may be faulty.
Posted on Jun 17, 2009
Rinse cycle water temp
You may have a leaking hot water electrovalve, replace it.
Sep 06, 2016 | LG WT4870CW 27" Top Load Washer with 4.5...
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Can I hook the wash and rinse to cold water hose?
Not sure what you are asking. If you want to wash and rinse you clothes in cold water only, there should be a water temp selection switch to allow you to do that. If you are asking if you can hook cold water hose to both ports on the washer back the answer is yes but it is easier to just cap off the hot side of the water valve on the back of the machine. Most machine water inlet valves are a 3/4 thread garden hose connection. Go to a hardware store or a Lowes/ Homedepot and ask for a screw on cap. They come in both plastic and brass. If you do cap the hot side of the inlet valve, make sure your washer has a cold only setting for wash and rinse and keep it set there. If it gets moved to hot nothing will fill or run.
Apr 15, 2015 | Washing Machines
Even when the machine is set to cold it pulls in hot
not sure on that one most machines are cold fill now,,think it is to do with the valves been closed , even though the machine is in a cold wash it registers a fault when any of the valves are closed
Nov 10, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Cold wash/rinse selected, but only hot water is used
I have a Sears front load washer and I also noticed that on a cold wash/cold rinse cycle the machine was drawing hot water.
Laundry detergents require water to be at a certain temperature to aid in disolve. The machine adds sufficient hot water, regardless of the cycle, until that temp is reached. If I was to use a cold water detergent the machine, because it has no way of knowing which detergent I'm using, will still add hot water until that minimum temp is released. I don't know if there are machines available which include detergent type as an option?
Sep 28, 2009 | Kenmore Washing Machines
Kenmore top load water temp switch problems and hot water rinse
Hi, Switch the hoses around going to the mixer/inlet valve. I am sure this will take care of the problem.
If not, please let me know so I can assist you further.
Vic
Jul 01, 2009 | Washing Machines
Washer is rinsing with hot wateer nomatter what temp. setting is used. I have tried to switch hoses twice now, no difference in rinse but now on correct wash temp.
The MAH5500 series washers have automatic temperature control functions so the washer can control water temp regardless of water heater settings and other factors. I would say either your definition of "hot" is not truly "hot" (over 110 degrees), or the washer's ability to sense has failed (which would also affect fill temp on "wash" fills also). If someone has worked on the washer recently, maybe they reversed the wiring to the water valves inside the machine? ATC temps are as follows: Cold 70-90, warm 90-110, and hot is unregulated at 110 degrees and up. These are normal temp ranges for ATC controlled machines, and are completely safe for fabrics.
Apr 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire washer hot water only
sundsas if you have a bad temp select switch. only selecting hot/hot
Oct 31, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
When temp is set on hot water--hot water shuts off & cold water comes out
In the machine, you have a solenoid that the water hoses come into. That piece is controlled by a timer. The hot water during the cycle, does it shut off completely during fill or intermittent?
Mar 16, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
137 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
