Question about Sony PlayStation 2 (PS2) Console
Disc Tray I opened my PS2 in order to re-adjust its lens. Now the Disc Tray will not open all the way. It does not look as though anything is impeding the tray, but it is hard to tell. Any suggestions?
  • g30g3 Nov 01, 2007
    i have the same probelm i cant open it
  • 709 Answers
You will need to get back the cover off and the laser tray cover off the fix this.
When putting the CD tray back in, the white piece that raises and lowers the Disc/laser frame has a white peg sticking up. before putting the Cd tray back in, slide the white piece all the way to the right towards the reset/eject buttons. guide the cd tray so that the white pin guides into the slot on the bottom of the cd tray. You might want to look at the bottom of the CD tray to see the track. The white pin/peg has to travel in this slot.
Posted on Nov 04, 2007
My Akai dvd player shows "no disc" after loading a dvd. The tray sometimes makes a grinding noise when opening and closing as well.
The reason the player is not reading the disc and showing no disc is either because the disc is not sitting properly on the lens from the disc tray, or the lens is weak or the lens is dirty.
To test if it is the disc tray, open the cover of the player with the appropriate screwdriver, place a disc directly on the tray and apply a little pressure on the tray, if it reads the disc, then it is the tray.
All you have to do is to adjust the disc tray and screw it tightly.
To test if the lens is weak, try several DVD disc on it,and test them also on another tested ok player, if it does not work on your player and works on other players, then the lens is weak.
to fix this, get the appropriate screwdriver, open the cover and unscrew the disc tray.
You will gain access to the lens, carefully disconnect the lens and replace it with a new lens. then it will be ok.
To test if it is just that the lens is dirty, clean the lens with a lens cleaner and test a DVD to see if it will work.
Take care.
Jun 14, 2010 | Akai DVPS760 DVD Player
Model 50001 fat ps2 cleaned the lens adjusted the arm...
If your lens is not moving up and down the track at all even in bootup then sounds like your motor is fried. What i'm referring to is this:
You can find similar parts like this .::HERE::.
To verify this, open your dvdrom tray. Power off the PS2 via the swtich on the back of the PS2 (thus leaving the dvdrom tray open) Tare down your PS2 and remove the four screws on the top of your DVD-ROM unit (if this is a fat model, if it's a slimline model you'll have to remove that whole platic piece covering the unit itself) You may have to do some research on this next part (via google) but remove your DVD-ROM tray so you can see the guts of the DVD-ROM. Then power on your PS2. And ask yourself the following questions as you observe.
1.) Does the lens move at all even right after bootup?
2.) Is the siver bar part of the motor(pictured above) turning at all to make it move?
If it doesn't turn at all then there is your problem. If it does turn, and the lens doesn't move at all then the ribbon cable that connects the lens to the board maybe damaged or the lens itself is damaged.
Hope that helps
Nov 08, 2008 | Sony PlayStation 2 (PS2) Console
Disc Tray
The rubber band inside your PS2 might be broken, the rubber band supports the disc tray and it ejects and inserts the tray.
Sometimes if play too much long, some of the PS2 parts will be damaged by excessive heat, so my advice is that your minimum gameplay time must be 3-4 hours only.
Please den't even try forcing the tray to open, it will be more damaged.
Try resting your PS2 for about 1-2 days, after that try to open the tray, if the problem still persist bring to a PS2 fixer near you.
Jul 29, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 will not read disc
Check your disk for scratches fingerprints ect,,
if thats all good step two
try useing a lens cleaner
****(( tip and trick for scratched disks ))****
a crayon rubbed on the disk then wiped off with a lint free cloth
no t-shirts dish towels that will just add more scratches
remember start at the center wipeing out to the edge.
if none of that works you may have a lens problem
Jan 04, 2008 | Sony PlayStation 2 (PS2) Console
Disc tray
yes you did.. on the back of the tray there is a wheel that has teeth like a gear.. it moves the lens/laser assembly up and down.. take a little time.. for the fine tuneing. look around on the back real good i have seen white,gray and black adjusters ..
Dec 29, 2007 | Sony PlayStation 2 (PS2) Console
My ps2 wont read any discs but it plays music discs and cd's
Hi Cozza,
Open the console up, and remove the cover over the Cd drive. Clean the lens of the Laser with a Q-tip lightly dampened with Rubbing alcohol. Use the dry tip of the Q-tip to dry the lens, look to see if you left any lint, and make sure the lens of clean.
Oct 31, 2007 | Sony PlayStation 2 (PS2) Console
Disc error
the best to do is the basics open your ps2 and inside open the disc box ( you can simply identify it it is the place where the disc is played) get a cotton buds and wipe gently and smoothly the lens. If
still it won't work go to your nearest repair man for further advice.
Oct 20, 2007 | Sony PlayStation 2 (PS2) Console
PS2 Won't Spin Disc!!!
is this the big ps2 or slimif the big one does it say disc read eror or something is yes the lens might be dirty so if you want to void the ps2 open it up screws under rubber tabs then open the drive where disc goes then lightly clean the lens with a cloth and try it then also does this happen with all the games or just one or two
Aug 13, 2007 | Sony PlayStation 2 (PS2) Console
Slimline PS2 disc not spinning
my friend i have a ps2 that its cd does not rotate ( i open it completely ) and the lens is working the lens is producing a red ray and it is movinng up and down but just the cd motor doesnot rotate so i checked the smd fuses using my fluke dgital multimeter i found one that is open when i replace it the ps2 work perfectly fine for your information the smd fuses are marked ps1 ps2 ps3 ps4 etc
Apr 30, 2007 | Sony PlayStation 2 (PS2) Console
PS2 problem
It's likely the lazer lens is out of alignment or requires replacing. Did your dvd cleaner also have a lens aligning part to it, you normally go through a spoken instruction(go to track 2 etc), as cleaning is sometimes not the only required solution.
Jan 08, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
127 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
