Question about GE Heating & Cooling
AC didn't blow cool air. Checked the compressor unit outside and the fan didn't work.
  • 116 Answers
If you could hear the compressor running then capicitor or fan motor bad if no compressor check for power to out door unit some times fuses at disconnect also on seperate breaker than indoor unit hope this helps
Posted on Jun 17, 2009
  • 49 Answers
SOURCE: Not Cooling
Yes, the compressor might not be running. Possibly a bad run capacitor or maybe burnt wires on the contactor or compressor flags.
Posted on Oct 27, 2007
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
  • 233 Answers
SOURCE: whirlpool central ac stopped blowing air, cool or
If you are refering to the indoor fan that is not running, but that the outdoor condenser is operating, the next place to check is the circuit board in the air handler, this is the control for the fan motor. the relay may be bad that actuates the fan circuit. if the relay is bad there will be no power to the fan motor. If you have power to the fan motor then the motor is bad and the motor and capacitor should be replaced.
Posted on Jul 20, 2009
SOURCE: AC Unit is not working
if you got high volt to the outdoor machine....make sure the thermostrat is in fact on.open the control box cover to the a/c.a round or oval soda pop lookin can thing should be visually noticeable.is it blown up.thecan top will be bulged.if it is the capacitor is defective.duel capacitors control phase shift for both motors...the outdoor fan and the compressor.a big black relay with the wires comming from the outdoor fuse box should be noticeable.this is the high volt contactor, is the contactor pulled in?beets the **** out of you???grab a screw driver by the insulated handle, not the metal part of the screw driver.manually push it in.did the fan start to go???if so bad contactor or no signal from t'stat to turn machine on.if not no high volt to machine(breaker tripped or failed) or fan motor seized leading to compressor O.L.
Posted on Aug 03, 2009
  • 233 Answers
SOURCE: our ac just suddenly stopped working. the fan
probably from the symptoms you describe the condenser fan motor has failed.If the fan is not running and the copressor is you need to shut the power off to the unit until it is repaired, the compressor can susstain damage from the lack of fan, and it is the most expensive component in the system to replace...
Posted on Aug 15, 2009
Unit stopped cooling, inside unit runs, outside unit does not
could be a gas leak ( low gas pressure shut off switch, failed start run capacitor for the compressor , vermin problem shorting out the power board outside
The inside unit is just a fan
call an accredited ac technician to get a proper diagnosis and quote
Aug 06, 2016 | Heating & Cooling
Ac compressor will not start
Hello, sounds like a faulty capacitor. Check the capacitor to see if it is puffed up at the terminals. It will be located inside the outside unit and looks like like a can that is oval or round.
Jun 17, 2012 | Goodman Heating & Cooling
AC compressor wiil not turn on
You will have to find the contactor which is located in the outside unit. And check the voltage at the contactor, 26 v as this is the thermostat calling for the compressor to come on. You can also push in the contactor and see if the fan and compressor start. There should be an outside fuse box close to your condensing unit. Good luck
Jul 23, 2010 | Samsung AW1203B Air Conditioner
Air Conditioner blows air, but does not cool
Go to the outside unit and see if the compressor is running. It may be hard to hear. If you need to you can disconnect one fan lead so you can hear the compressor. If it isn't running then check the capacitor. If it is running then get the refrigerant charge checked. Also check air filter(s) and make sure the coils are clean.
Jul 17, 2010 | Heating & Cooling
Our ac just suddenly stopped working. the fan inside the house is blowing out air, just not cool air. i checked the ac unit outside and the fan blades are not moving, but can hear something in there making...
Aug 15, 2009 | Heating & Cooling
My fan isn't working
well there not enough data here to make a fairly good solution. but if all the fans are running! and no cool air then it is the compressor.
Jul 14, 2009 | Heating & Cooling
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Not Cooling
Oct 26, 2007 | Weather King 10AJA3601AH Air Conditioner
Heating & Cooling Logo
118 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Andrew Taylor
Andrew Taylor
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
