Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
I have an 80 gb zune that only shows the backlight
The computer recognises it and i still have all my music. any advice would be awesome because i dont want to have to replace the screen thank you
Ok, so I just recently had this same problem. I m not gonna lie, I dropped mine and only the back light came on. but, I did a hard reset which is back key, and up key at the same time. then it wouldnt even play music. So I attached it to my laptop to let it sync with my zune. then I charged it. And put it in "deep sleep mode" which is back button and down on the directional pad. after that i turned it on, and started hitting some random keys. And now it works, except I dont know what song is playing till i hear. But it will buy me time at least. best of luck.
Posted on Jul 16, 2010
8 gb zune does not take a charge or turn on.
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | zune.net
Have a 80 GB Zune. It froze one day and was showing the message 'Connect the player to your PC'. I did that but then some error message started appearing in the Zune PC software. I tried formatting the...
Try the reset procedure...
hold the back button and the up button until you see the Zune logo then release. if this doesnt work then you are going to have to reset your Zune....however this will loose all the data on the zune so your music/movies will be completely gone. you are going to need to press and hold the back and up button until the zune logo appears then hold the back,play/pause, and the center button until you see "please wait"
Jan 02, 2011 | Microsoft Zune JS8-00001 Digital Media...
80GB Zune showing error 5 - Contact support
You can fix it but it's very fragile inside the hard drive is broken internally i would send to rapid repair and have the upgrade done. The software you need after the fix is hard to come buy because it has to go through a Microsoft sever that doesn't exist anymore. There is a fix for that on utube. You will have to trick the software on your computer to be the server. Hope that helps.
Oct 26, 2017 | Microsoft Zune JS8-00001 Digital Media...
How do I delete all my music from the Zune 120 gb.? I have updated many music files with the correct information regarding artist, title, genre, etc and eventho the sodtware recognises the changes it never...
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 25, 2009 | Microsoft Zune JS8-00001 Digital Media...
Can't download music
You will probably have to move the music from your blackberry to your computer, then use the Zune software to sync the music to your zune. You'll have to tell the Zune software where to find your music, unless you put the music in the Zune music folder (My Music in "My Documents" is the default).
Best of luck!
Jun 20, 2009 | Microsoft Zune JS8-00001 Digital Media...
My zune 80 gb was working great and i have a lot music on it and now it says the item is missing or cant be played WHAT CAN I DO TO FIX THIS PROBLEM AND CAN I SAVE MY MUSIC ALREADY DOWNLOADED ON IT
you may have some songs on it that are not compatible or just not a good music file.
when you see that error delete the song and see if any others will play.
some files may have been corrupted, you also could have downloaded a virus
May 16, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune 30GB
i'm sure that you will not be able to get your music from the connection from your other device because your computer identifies your zune as the name you if you put your "new used one" then it will not come up as " our stolen one "
May 30, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune keeps freezing up...
JUST HOLD THE BACK BUTTON AND THE UP BUTTON FOR 30 SEC. AND YOU WILL BE GOOD DON'T WORRY PEOPLE.... ALSO WHEN I FREZZE ALOT THAT MEANS YOU DATA ON THE ZUNE IS COUPPORTED AND YOU WILL NEED TO RESET THE WHOLE DEVICE OK.
Feb 19, 2008 | Microsoft Zune JS8-00001 Digital Media...
Music stops and zune freezes up
uhm i think i may have found your solution, that is if your using limewire or some client of the sort, i synced my zune while the program (limewire) was on and downloading music and i had the same problelm you did so i simply deleted all my music and put it back on the zune while limewire was off and now it works fine, i have an 80 gig btw if that matters
Feb 10, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
175 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
