Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Replaced bulb on PT50LC13 5 months ago. Now a box pops up when I turn the tv on saying to reset the timer. How?
  • 3 Answers
Oh now I get it - on the TV itself press the volume down button and then on the remote at the same time press the pip button. Works ! :) I was pressing the volume down button & the pip button on the remote at the same time - oops...no wonder it didn't work that way:) thanks for the help!
Posted on Jul 25, 2009
    Problem Solver:
  • 5 Answers
1. MAKE SURE POWER CORD IS PLUGGED IN.
2. WHILE PRESSING THE VOLUME BUTTON ON THE PROJECTION DISPLAY,HOLD DOWN PIP0R SPLIT BUTTON ON THE REMOTE CONTROL AT THE SAME TIME FOR MORE THAN 5 SECONDS.
3. WHEN THE RESET IS COMPLETE, THE SCREEN ON THE RIGHT WILL APPEAR AND IT SHOULD SAY "LAMP TIME RESET TO "0"
Posted on Jul 05, 2009
I have a Mitsubishi 60inch 60737 replaced the bulb last month.now it keeps cutting off,cleaned the filter before.someone said to reset bulb timer,how do I reset it.
The Lamp timer will not cause it to shut down. The timer should have been reset when you first turned the TV on after replacing the bulb. Make sure your bulb is an Osram brand bulb. If not, then you do not want to use it as it may not be very good.
May 27, 2015 | Mitsubishi Televison & Video
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
My 42e2000 just said "lamp at end of projected life". I have had this TV for several years, have had it isf calibrated 3 times (the last time was 1 month ago). At that point, the technician said everything...
I recomend chnge the lamp now to avoid ballast problem after.and remember reset the lamp timer after change.for reset lamp timer press menu in the remote control ----setup------in the color adjust side find lamp reset ----a change a new lamp question appear--push yes and ok.
Apr 09, 2010 | Sony KDF42E2000 42" HDTV
When I turn my tv on, there is a box that comes on and says replace lamp bulb and lamp timer, I changed the bulb but I do not know how to change the timer?
I can help you reset the lamp timer for your Panasonic PT-61LCX66 Projection HDTV.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Mar 28, 2010 | Panasonic PT-61LCX66 Television
Just replaced bulb to a phillips, lasted one month
Most systems with lamps will have a timer. If the timer gets to a certain hour the set should warn you to replace the lamp. Once you do, you have to reset the timer. If it gets to the max it will not allow you to turn it on till the timer is reset. Check your manual or call the mfg. to see how to reset. Sometimes it's the volume up and down at the same time or menu and power at the same time. They are all different so if you have no manual it's best to call tech support to get the reset steps.
Jul 17, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No picture
ballast is not striking the lamp and needs replacing
Jan 10, 2009 | Sharp XR-10X Multimedia Projector
Jvc av-32fa44 tv--loud pop, then off and won't turn back on. buy new?
Its the power cap mine did the same thing about 11 months into daily use
Oct 24, 2008 | JVC AV-32FA44 32" TV
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
285 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
