Question about Minolta Office Equipment & Supplies
Copier jams in imaging unit
I have a minolta cs prp 2030 copier that is jamming in the imaging unit becusae the toner/starter is coming out of the unit and jamming against the drum on the rear side(towards the back of the machine). The machine is level.
  • 1,800 Answers
Hello
is there any error code on the Display?
Posted on Jun 17, 2009
Erro c oo copiadora minolta 2030
Check the fuser unit remove it (THE HOT PART) check for broken gears and also check inside once removed, also check the drum assy., check that drum can turn remove image unit, the using thumbs on each end turn the drum clockwise. if the cleaning blade is yellow replace it.
for parts try this site. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 27, 2011 | Minolta EP4000/5000 CS/PRO Copier
Toner cartridge wiil not come out? paper is jammed brother 2030
You need to open the front door and grab the toner/drum unit and pull as hard as you need to. once the assy. comes out you press the blue button on the left side and the toner cartridge will separate from the drum unit. install the new toner or remove the paper jam as required. call if you need more info. 805-520-3003 steven
Feb 13, 2010 | Brother HL-2030 Laser Printer
Original Pad
Please related your problem detailated for help you.You have on Minolta CS Pro 2030,describe your problems,and I help you.
Nov 23, 2009 | Office Equipment & Supplies
Minolta cs pro 2030 copier losing developer then jams with error C0000
C000 is a main motor lock code. A developer change may help. It may be two seperate problems too. The fuser unit has some drive gears that tend to break and lock the machine. This is an old analog machine, you REALLY don't need to spend much money on this one.
Jun 24, 2009 | Office Equipment & Supplies
Minolta cs pro 2030 copier imaging unit jams
The doctor blade is set to wide. The brush on the magnetic roller should be solid but not dumping.
Jun 17, 2009 | Office Equipment & Supplies
MINOLTA EP 2030 Photocopier
if it powers up and goes into rotation then the fuser is good. So check the machine for paper jams, toner,
does it give an error? is there a symbol light on?
Sep 09, 2008 | Minolta EP1030/1030F CS/PRO Copier
Minolta ep 1030
It is not actually a paper jam - when the copier detects a malfunction, it simply stops everything. Paper jams all have "J" codes (J1, J3, etc.).
A CF3 indicates a problem with the ATDC system (Automatic Toner Density Control). The output from the ATDC sensor is outside normal specs.
Possible causes would include the copier being run (and reset repeatedly) without toner, the imaging unit not being properly installed (or not present at all), use of toner not compatible with the unit, a defective ATDC sensor or (least likely) PWB-A.
Jul 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
Paper jams and c f 3 flashes
CF3 - ATDC sensor malfuntion. This sensor measures the density between toner and developer. You might have a problem with too short developer. Add some more and do F8.
The manual says basically that you either have a problem with de sensor (under a bottom plastic plate of the image unit) or the main board (PWB-A).
Kyocera CS 2030 fax jams
Hi,check settings for fax.Try to check paper attributes for fax.Maybe You have different paper format adjusted for fax printing.
Oct 19, 2007 | Copystar CS-2030 Copier
21 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
