Question about Leviton Decora Light Dimmer Switch
Light dimmer issue
I installed a Leviton 6631-LW slide dimmer- the indicator light on the switch itself is on showing that the connection is good, but the actual light doesn't go on- what did I do wrong? Previously there was just a regular light switch.
  • marycyb Jun 17, 2009
    Thank you! The original switch connection had only two wires- one for the ground, and the other was connected to the two other wires coming from the wall. The new switch had three wires to connect- the ground, and then I just seperated the two other wires... should i try to leave one of the switch wires with no connection and connect the two wall wires together?
  • 21 Answers
The light on the switch does not men it is wired correctly, it only means that you have supplied power at that point. Without knowing more its hard to say, but I'll assume this is a single switch operating a single unit. That being the case, and depending on your fixture, occassionally wires must be grouped together on the switch side. Also quite often these switches are simply defective, and must be returned. If you think you have it correct then its probably a bad switch.
Posted on Jun 17, 2009
Dimmer slide does not dim
Replace it. They fail and and that is not uncommon. good luck
May 20, 2018 | Leviton Electrical Supplies
Locator Light not working on leviton 6633-pl
6633-pl is single-pole and 3-way dimmer made for max 600 watt incandescent or halogen load. This dimmer does not work for CFL or inductive loads such as motor.
I have no idea what a 'locator light' is?? Do you mean the LED indicator that shows when power is connected?
Troubleshoot section of manual does not show any solution for LED malfunction.
Contact Leviton for email tech support:
http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=37619&minisite=10251
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 03, 2012 | Leviton Decora Light Dimmer Switch
How to you install a Leviton Slide Dimmer with Preset No. IPI06 to a double switch box where one switch controls the ligth fixture over the table(the one I want to connect the dimmer to) and the secon
Hi Velie,
I am an electrician and can help you wire this switch. If I understand correctly, you have a two-gang switch box in the wall. In it, you have two switches installed. One switch is a 3-way type, and is one of two (or more) switches used to control preparation area lighting. The other switch is a single pole type and controls a light over your kitchen table. Right?
If this is correct, remove the double switch wall plate. Let's set aside concerns with the 3-way switch. We have nothing to do to this switch so we will not need to remove it from the box, nor will we need to disconnect it. It works independently of the switch that controls the light over the table.
Remove the switch that operates the light over the table. If it is indeed a single pole switch, it will have just two terminals for wires to connect. It will probably also have indications for ON and OFF on the handle. If installed correctly, flipping the toggle up or pressing the top of the switch will turn the light on. If is a 3-way switch, it will have terminals for 3 wires to connect. One of the terminals will be a dark color from the other two. Additionally, no ON and OFF markings are on the switch handle and the light may turn on in either handle position (depending on the position of other switches controlling the light). With this information, I assume that you have now verified that it is in fact, a single pole switch. Right?
If all is going as expected, then we can continue. Shut off the power. Since a single pole switch has only two wires to connect, this should be fairly easy to do. One terminal should have a single wire that goes to the light over the table. The other terminal should have a wire that is powered all the time. It is very possible that the wire that connects to this terminal is ALSO is connected to the the 3-way switch either directly, or by a short length of wire that has a wirenut to connect several wires together. If you need to verify a connection to the 3-way switch, remove the switch from the box if needed (do NOT disconnect any wires). The wire should be connected to the dark colored terminal screw of the 3-way switch. This would indicate that this wire - and those connected by wire nut to it - is the source of constant power. Carefully fold the wires into the box and re-secure the 3-way switch if you pulled it from the box.
You new switch has a single RED wire and TWO black wires. Twist a wirenut cap on ONE of the black wires (it does not matter which). Remove the wire that was determined to be powered all the time (was also connected to the 3-way's dark colored terminal) from the old switch, and twist it around the dimmer switch's remaining BLACK wire with a wirenut. Disconnect the remaining wire from the old switch and twist it around the dimmer switch's RED wire with a wirenut. Add the dimmer switch's GREEN wire in to the bundle of uninsulated ground wires in the wirenut inside the box. Fold all the wires gently into the box and secure the dimmer to the box. Install the wall plate and turn on the power.
I hope this helped & good luck!
Feb 10, 2012 | Leviton MFG L00-IPI06-1LM DIMMER SLIDE...
We have Leviton push button slide dimmers w/the locate lights for power outlets and lights throughout our house. A couple of months ago one stopped working...you push the button to turn it on and it...
Wiring is not best suspect.
If all the Leviton devices were installed same time, they may be failing at same time due to lifespan.
For example, ordinary on-off switch is a mechanical device with mechanical parts, and mechanical switches last many years longer than wiring devices that have electronic parts.
Electronic devices usually have standard 1 year limited warranty.
http://www.leviton.com/OA_HTML/ibeCZzpHome.jsp?minisite=10025&respid=22372
Jun 29, 2011 | Leviton Decora Light Dimmer Switch
Needed to turn another circuit off to change a bathroom light fixture. In the process of finding the correct breaker for this project, another circuit was tripped for my dining room where there is a...
Just tripping the breaker should no affect your dimmer unless maybe malfunctioning or wired incorrectly or loose connection. It is hard to wire incorrectly, for there should only be two wires attached to the dimmer? Replace dimmer and make sure wiring is correct if not sure about wiring yourself contact local electrician for your safety. There are very good instructions inside the switch packages, make sure to buy a quality switch, Leviton is a good name I would lean towards faulty switch or loose connection but I'm not there. Good Luck Karen....
Apr 20, 2011 | Home
I just installed a Leviton IP106 Illumatech dimmer switch. It was replacing my existing rotary dimmer switch. The switch is a 3-way wiring job, with another 3-way toggle switch (no dimmer) on the other...
The Leviton IP106 Illumatech dimmer switch must be installed at the switch location where the hot feed exists. From your description your hot feed is at the regular 3-way switch location. Swap locations.
Dec 22, 2010 | Leviton Decora Light Dimmer Switch
I replaced my old 3way toggle switches with the LEviton 5613 3way lighted rocker switches. Wired exactly the way the older toggle switches were wired. Switches work fine just like the older ones but one...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=4044§ion=10103&minisite=10025
The Leviton page for Leviton 5613 does not have a troubleshoot.
Manual shows simple wiring diagram.
3-way switches will not operate lights if switches are wired incorrectly.
Check your ground wire is connected.
Leviton 5613 series is illuminated.
Check that both switches have 5613 number.
Swap switches and see if problem is inside switch.
Nov 13, 2010 | Leviton 5613-2WSP Grounded Switch
Leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
Nov 02, 2008 | Leviton Decora Light Dimmer Switch
Leviton  Decora Light Dimmer Switch Logo
333 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
Gene Haynes
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
