Question about Kenwood Audio Players & Recorders
KEnwood SW-305 no out put
I have a Kenwood SW-305 that does not output any sound. I have checked the fuses and they ohm good. The power light comes on but no volume. I put another sub on the system to see if there was a problem with the pre out and the second sub worked.There appears to be no measureable out put to the speaker. I did check the speaker on a different sub amp and it did work.Any ideas?
SOURCE: sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Posted on Oct 09, 2007
furion187
  • 54 Answers
SOURCE: 4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Posted on Dec 09, 2007
  • 54 Answers
SOURCE: Fuse keeps blowing?
The fuse is a protective device. Fuses dont blow unless the amp ( in your case ) is drawing too much current. DO NOT put a bigger fuse in. Obviously, there is a problem with the amplifier inside the sub. If the sub is under warranty, send it in for repair to an authorized warranty depot. If not it's not under warranty, then take it to the authorized warranty depot anyway. Why ? because they will have the schematics ( electrical diagrams ) to troubleshoot the unit quickly and it may be a common problem. If it is a common problem, the factory may have released a modification and possibly it could be covered under warranty under a factory 'goodwill' program. Good luck. Rob
Posted on Mar 03, 2008
pjstanley
  • 185 Answers
SOURCE: one of 2 subs stopped working.
ya the sub is blown or the amp channel is blown
Posted on Apr 10, 2008
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
I have Kenwood SW 900 . need to know its out put. Kept for long period
Do you mean the Kenwood SW-200 subwoofer or the SW-200 power meter? The subwoofer can use 50W RMS at 4 Ohms. It's rated at 60W. The power meter reads in two ranges: 20W and 200W.
Kenwood has the manual for the subwoofer on their support site. The direct link to the manual is http://kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/sw200.pdf .
I hope this helps. If you are looking at a different Kenwood product, please clarify which product you have. I can't find a SW 200 receiver from Kenwood.
Mar 08, 2016 | Kenwood Car Audio & Video
Kenwood sw-35ht Replace with a kicker sub
I suppose you could, but you are talking about a driver (speaker) that was not designed for that cabinet size and amplifier used in the Kenwood, There are differences in speaker design besides power rating and impedance.
Jun 10, 2014 | Kenwood SW-38HT Subwoofer
Kenwood kac 628 red light comes on and no audio output
The red light you describe on your amp, is the protection mode warning light. An amp goes into protect for many reasons. Here's a checklist.
1st check the fuse (s) on your amp and make sure they are not blown.
2nd check the inline fuse next to your car battery (if you have an inline fuse)
3rd, disconnect the speaker wires with amp on, does the light go off?
4th check your ground, this may be ok if you have tried another amp with the same wires.
5th.if none of these turns the protect mode off, it may be an internal fault.
you may have blown transistors and it is a tricky job to repair and costly.
Jan 28, 2013 | Kenwood KAC-628 Car Audio Amplifier
I need an appropriate speaker for my kenwood amplifier kac-5202
This amp is stable down to 4 ohms bridged at 120 Watts or 2 ohms stereo at 60 Watts X 2. If you are going with the bridged mono hookup just make sure the impedance of your subwoofer is no less than 4 ohms. A good rule of thumb is to be at least double of what your amps rated output power is. So if your amp can put out 120 Watts into 4 ohms then get at least a 240 watt subwoofer.
Do not exceed the rated load for your amp, you will damage it. Here is the datasheet for your amplifier
http://manual.kenwood.com/files/B64-3031-00_En.pdf
Jun 12, 2011 | Kenwood KAC-5202 Car Amp
Seems as if the amp is putting out minimal power...its hard to say since i have 4 subwoofers in the vehicle...one set is ran by a sony amp pushing 540 rms in a vented enclosure and the other set is being...
do you have caps before your power going into the amps, might not be getting enough power, check your settings on the amp, gain output make sure it in stereo and not mono and check your crossover, or splitter
Jan 10, 2011 | Kenwood eXcelon X1200M Car Amp
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
My Kenwood KAC-929 gets power but DOES NOT put any sound out. Whats My Possible problem(s).
Hello Spicer_kyle6,
Possible problems: 1) No output from the head unit. Try a different set of preamp outs. 2) No input to the amp. Check the RCA's and make sure that they are good and coming from a functioning preamp or subwoofer output on the head unit. 3) Input gain turned off or down too low. 4) Speaker wiring shorted, grounded, or open. Check all wires. 5) Speakers defective. Connect to a known good output to test. 6) The amp itself could be defective and still show a power-on indication.
Hope this helps.
Apr 28, 2009 | Kenwood KAC-929 Car Audio Amplifier
Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
Apr 14, 2009 | Kenwood Car Audio & Video
No sound from my woofer
Check your speaker connections... try using a multimeter set to "OHMS" and see if the speaker is reading around 4-8 ohms... if it shows no reading there is no continuity in the coil of the speaker
Mar 24, 2009 | Kenwood KAC-929 Car Audio Amplifier
I have a Kenwood Subwoofer, SW-305, S/N 00901468, that when the power is one and hooked up there is a loud buzzing sound. No audio comes out of the subwoofer. I have checked and rechecked my conections and...
please try to replace your RCA plug that connects from your input player to your Kenwood Subwoofer..coz it not have open ground or has no continuety in it
Dec 05, 2008 | Audio Players & Recorders
203 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
