Minolta cs pro 2030 copier imaging unit jams
The imaging unit jams by having to much toner/stater jam up against the drum causing it to stop turning. It gets jammed up on the back end of the drum.
  • 143 Answers
The doctor blade is set to wide. The brush on the magnetic roller should be solid but not dumping.
Posted on Jun 26, 2009
Minolta cs pro ep 1085 errore code c0010
Sir/Mam the Drum Motor is failing to turn the drum it self mite be jammed. Not allowing the motor to turn . Remove the drum cartridge. And see if you can turn the drum with your fingers DO NOT TOUCH The color part of the drum turn by both thumbs on the edge of the drum TURN CLOCKWISE if you turn Counter clockwise you will flip the cleaning blade that is not good. The cleaning blade removes the old toner before the new image is placed on the drum if it looks yellow then get a new one and replace it. IF you think the drum is stuck to the cleaning blade then for about a half inch push the drum counter clockwise the then clockwise. Also might remove he drum to see if its jammed. Also the motor might be bad or the circuit board that replaces it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 23, 2013 | Minolta Office Equipment & Supplies
Minolta ep4000 showing code C000 Drive problem how to resolve it..
Remove the fuser (The hot unit) fist and check for broken gears or jammed gears. Next check the gears in the rear where you removed the fuser. also remove the drum cartridge and check that the drum rotates ok do not touch the drum must use the sides only. Turn only in the clock wise or you might flip the cleaning blade. Which is what removes the old toner before the next image is placed on the drum. If it is yellow looking replace it. Located on the left side of the drum. Open close the front door reset the code.
Aug 18, 2013 | Minolta EP4000/5000 CS/PRO Copier
How to change the drum cartdrige.
Remove the imaging unit ,remove the charge corona assy,remove the OPC drum,remove 2 screw and dump the developer out.Reinstall the imaging unit ,pull out the toner cartridge and push in toner cartride ocation the developer cartridge.Turn on the copier and wait then the copier perform the new developer initialization.Whwn the Start button in ready(green light),change the developer cartridge to toner cartridge.
Mar 05, 2013 | Minolta EP1031/1031F CS/PRO Copier
Erro c oo copiadora minolta 2030
Check the fuser unit remove it (THE HOT PART) check for broken gears and also check inside once removed, also check the drum assy., check that drum can turn remove image unit, the using thumbs on each end turn the drum clockwise. if the cleaning blade is yellow replace it.
for parts try this site. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 27, 2011 | Minolta EP4000/5000 CS/PRO Copier
Toner cartridge wiil not come out? paper is jammed brother 2030
You need to open the front door and grab the toner/drum unit and pull as hard as you need to. once the assy. comes out you press the blue button on the left side and the toner cartridge will separate from the drum unit. install the new toner or remove the paper jam as required. call if you need more info. 805-520-3003 steven
Feb 13, 2010 | Brother HL-2030 Laser Printer
Original Pad
Please related your problem detailated for help you.You have on Minolta CS Pro 2030,describe your problems,and I help you.
Nov 23, 2009 | Office Equipment & Supplies
MINOLTA EP 2030 Photocopier
if it powers up and goes into rotation then the fuser is good. So check the machine for paper jams, toner,
does it give an error? is there a symbol light on?
Sep 09, 2008 | Minolta EP1030/1030F CS/PRO Copier
Minolta ep 1030
It is not actually a paper jam - when the copier detects a malfunction, it simply stops everything. Paper jams all have "J" codes (J1, J3, etc.).
A CF3 indicates a problem with the ATDC system (Automatic Toner Density Control). The output from the ATDC sensor is outside normal specs.
Possible causes would include the copier being run (and reset repeatedly) without toner, the imaging unit not being properly installed (or not present at all), use of toner not compatible with the unit, a defective ATDC sensor or (least likely) PWB-A.
Jul 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
Paper jams and c f 3 flashes
CF3 - ATDC sensor malfuntion. This sensor measures the density between toner and developer. You might have a problem with too short developer. Add some more and do F8.
The manual says basically that you either have a problem with de sensor (under a bottom plastic plate of the image unit) or the main board (PWB-A).
124 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
